Ana içeriğe geç
Datawind Ubislate 7ci Battery Replacement
Neye ihtiyacın var
  1. Datawind Ubislate 7ci Battery Replacement, Battery: adım 1, 2 resimden 1. Datawind Ubislate 7ci Battery Replacement, Battery: adım 1, 2 resimden 2.
    • Run your prying tool along the front edge of the device to pop off the front cover.
    • Once the halves are separated your device should look like this.
    • Be careful of the device's small wiring when separating the two halves.
  2. Datawind Ubislate 7ci Battery Replacement: adım 2, 3 resimden 1. Datawind Ubislate 7ci Battery Replacement: adım 2, 3 resimden 2. Datawind Ubislate 7ci Battery Replacement: adım 2, 3 resimden 3.
    • Remove the black tape.
    • Be careful not to remove the tablet camera.
  3. Datawind Ubislate 7ci Battery Replacement: adım 3, 3 resimden 1. Datawind Ubislate 7ci Battery Replacement: adım 3, 3 resimden 2. Datawind Ubislate 7ci Battery Replacement: adım 3, 3 resimden 3.
    • Use a soldering iron to remove the battery from both its attachment points.
    • Pry off the battery using an opening tool.
  4. Datawind Ubislate 7ci Battery Replacement, Replacing the Battery: adım 4, 2 resimden 1. Datawind Ubislate 7ci Battery Replacement, Replacing the Battery: adım 4, 2 resimden 2.
    • Insert your replacement battery in the same spot as the old battery.
    • Tape battery into place.
  5. Datawind Ubislate 7ci Battery Replacement, Closing the Tablet: adım 5, 2 resimden 1. Datawind Ubislate 7ci Battery Replacement, Closing the Tablet: adım 5, 2 resimden 2.
    • Solder the new battery to the connection points.
    • Press the back cover on firmly until it clicks.
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Mekides
40 İtibar
3 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 6-3, Vijaybhaskar Fall 2014 UMass Dartmouth, Team 6-3, Vijaybhaskar Fall 2014 üyesi
UMASSD-VIJAYBHASKAR-F14S6G3
3 Üyeler
6 adet Kılavuz yazıldı
2 Yorum
On my 7Ci the battery is SFH-HLKJ-204.
Datawind doesn't sale those pieces.
Where can I find one?
What type is it, voltage and so?
THX!
ylco - Yanıt
3.7V, 2200mAh lithium ion. Yiu can get a bigger or smaller one depending on shat you want.
Jessica Parnelli Fawkes - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 14
Her zaman: 9,032
