Ana içeriğe geç
Datawind Ubislate 7ci Rear Facing Camera Replacement
Neye ihtiyacın var
  1. Datawind Ubislate 7ci Rear Facing Camera Replacement, Finding a work space: adım 1, 1 resimden 1.
    • Be sure to repair your device on a clean surface so you are less likely to lose small parts.
  2. Datawind Ubislate 7ci Rear Facing Camera Replacement, Pry open your tablet: adım 2, 2 resimden 1. Datawind Ubislate 7ci Rear Facing Camera Replacement, Pry open your tablet: adım 2, 2 resimden 2.
    • Run your prying tool along the front edge of the device to pop off the front cover.
    • Once the halves are separated your device should look like this.
    • (HINT: be careful of the device's small wiring when separating the two halves.)
  3. Datawind Ubislate 7ci Rear Facing Camera Replacement, Removing the tape around the camera: adım 3, 2 resimden 1. Datawind Ubislate 7ci Rear Facing Camera Replacement, Removing the tape around the camera: adım 3, 2 resimden 2.
    • Remove the black tape that is circled.
    • The camera is circled in this picture.
  4. Datawind Ubislate 7ci Rear Facing Camera Replacement, Removing the camera: adım 4, 2 resimden 1. Datawind Ubislate 7ci Rear Facing Camera Replacement, Removing the camera: adım 4, 2 resimden 2.
    • Carefully remove the camera from its housing.
  5. Datawind Ubislate 7ci Rear Facing Camera Replacement, Inserting the Replacement Camera: adım 5, 2 resimden 1. Datawind Ubislate 7ci Rear Facing Camera Replacement, Inserting the Replacement Camera: adım 5, 2 resimden 2.
    • Slide the new camera into its housing carefully.
    • it should look like the second picture when you are finished
  6. Datawind Ubislate 7ci Rear Facing Camera Replacement, Closing the Tablet: adım 6, 1 resimden 1.
    • Press the back cover of the tablet on firmly until it clicks
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Mekides
40 İtibar
3 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 6-3, Vijaybhaskar Fall 2014 UMass Dartmouth, Team 6-3, Vijaybhaskar Fall 2014 üyesi
UMASSD-VIJAYBHASKAR-F14S6G3
3 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 9
Her zaman: 291
