Ana içeriğe geç
Datawind Ubislate 7ci Speaker Replacement
Neye ihtiyacın var
  1. Datawind Ubislate 7ci Speaker Replacement, Finding a workspace: adım 1, 1 resimden 1.
    • Be sure to repair your device on a clean surface so you are less likely to lose small parts.
  2. Datawind Ubislate 7ci Speaker Replacement, Pry open your tablet: adım 2, 2 resimden 1. Datawind Ubislate 7ci Speaker Replacement, Pry open your tablet: adım 2, 2 resimden 2.
    • Run your prying tool along the front edge of the device to pop off the front cover.
    • Once the halves are separated, your device should look like this.
    • (HINT: be careful of the device's small wiring when separating the two halves)
  3. Datawind Ubislate 7ci Speaker Replacement, Removing the speaker: adım 3, 1 resimden 1.
    • Use your prying tool to pop the speaker out from its housing.
  4. Datawind Ubislate 7ci Speaker Replacement, Detach from contact points: adım 4, 1 resimden 1.
    • Use a soldering iron to remove the speaker from its contact points.
  5. Datawind Ubislate 7ci Speaker Replacement, Attaching replacement to contact points: adım 5, 1 resimden 1.
    • Solder your new speaker to the same contact points as before.
  6. Datawind Ubislate 7ci Speaker Replacement, Housing the replacement speaker: adım 6, 1 resimden 1.
    • Apply a small amount of adhesive to the new speaker, and place it into the housing on the back panel.
  7. Datawind Ubislate 7ci Speaker Replacement, Putting your tablet back together: adım 7, 2 resimden 1. Datawind Ubislate 7ci Speaker Replacement, Putting your tablet back together: adım 7, 2 resimden 2.
    • Put the two halves back together.
    • Push down on the edges until you hear them click into place.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Mekides
40 İtibar
3 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 6-3, Vijaybhaskar Fall 2014 UMass Dartmouth, Team 6-3, Vijaybhaskar Fall 2014 üyesi
UMASSD-VIJAYBHASKAR-F14S6G3
3 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 10
Her zaman: 286
