Ana içeriğe geç
How To Remove Rust From Old Tools
Neye ihtiyacın var
  1. How To Remove Rust From Old Tools, How To Remove Rust From Old Tools: adım 1, 2 resimden 1. How To Remove Rust From Old Tools, How To Remove Rust From Old Tools: adım 1, 2 resimden 2.
    • Removing rust generally isn't dangerous, but it's pretty messy.
    • Prepare your workspace by laying out an old towel or shop rag that you won't mind getting dirty.
    • Consider also wearing protective gloves.
    • Place your tool on the towels.
  2. How To Remove Rust From Old Tools: adım 2, 2 resimden 1. How To Remove Rust From Old Tools: adım 2, 2 resimden 2.
    • Spray the rusty areas of the tool with a generous amount of WD-40.
  3. How To Remove Rust From Old Tools: adım 3, 3 resimden 1. How To Remove Rust From Old Tools: adım 3, 3 resimden 2. How To Remove Rust From Old Tools: adım 3, 3 resimden 3.
    • Use a scouring pad to thoroughly scrub the tool.
    • It shouldn't take a lot of force—the WD-40 and scouring pad will do most of the work.
  4. How To Remove Rust From Old Tools: adım 4, 3 resimden 1. How To Remove Rust From Old Tools: adım 4, 3 resimden 2. How To Remove Rust From Old Tools: adım 4, 3 resimden 3.
    • Use a paper towel to wipe away the excess grime and WD-40.
  5. How To Remove Rust From Old Tools: adım 5, 1 resimden 1.
    • Continue scouring the tool, adding more WD-40 as needed, until the surface is free of rust.
    • When you finish, your tool may not look brand new—but the surface should now be rust-free and ready for years of continued use.
Sonuç
8 farklı kişi bu kılavuzu tamamladı.
Geoff Wacker
90.145 İtibar
89 adet Kılavuz yazıldı
2 Yorum
Apple cider vinegar removes rust well. Try it.
Michael Jucker - Yanıt
Thank you I have tried vinagar ,rust buster and other sprays and only the WD 40 worked best
Ronald Tyler - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 19
Son 30 gün: 114
Her zaman: 4,562
