Ana içeriğe geç
TiVo Series 2 TCD24008A Power Supply Replacement
Neye ihtiyacın var
  1. TiVo Series 2 TCD24008A Power Supply Replacement, Cover: adım 1, 1 resimden 1.
    • Unscrew the five 0.31 inch T-9 screws on the back cover.
  2. TiVo Series 2 TCD24008A Power Supply Replacement: adım 2, 1 resimden 1.
    • Slide the cover towards the back until it is no longer under the front cover.
  3. TiVo Series 2 TCD24008A Power Supply Replacement: adım 3, 1 resimden 1.
    • Lift the cover up and off the device.
  4. TiVo Series 2 TCD24008A Power Supply Replacement, Power Supply: adım 4, 1 resimden 1.
    • Locate the power supply.
  5. TiVo Series 2 TCD24008A Power Supply Replacement: adım 5, 1 resimden 1.
    • Remove the belt connecting the power supply to the motherboard by pulling it out.
  6. TiVo Series 2 TCD24008A Power Supply Replacement: adım 6, 1 resimden 1.
    • Remove the red, yellow, and black cable connecting the power supply to the hard drive.
  7. TiVo Series 2 TCD24008A Power Supply Replacement: adım 7, 1 resimden 1.
    • Remove the two 0.31 inch T-9 screws from the power supply.
  8. TiVo Series 2 TCD24008A Power Supply Replacement: adım 8, 2 resimden 1. TiVo Series 2 TCD24008A Power Supply Replacement: adım 8, 2 resimden 2.
    • Pinch the plastic plugs and lift the power supply up to detach from plugs.
    • All 4 plugs must be detached to remove power supply.
Sonuç
Phil Jones
41 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 5-33, Amido Fall 2011 Cal Poly, Team 5-33, Amido Fall 2011 üyesi
CPSU-AMIDO-F11S5G33
4 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 14
Her zaman: 1,210
