Ana içeriğe geç
How to Use a Hair Dryer to Soften Adhesive
Neye ihtiyacın var
  1. How to Use a Hair Dryer to Soften Adhesive, Safety precautions: adım 1, 1 resimden 1.
    • Before you begin, make sure you have a plan in the event of a fire. If you have a swollen battery, take appropriate precautions.
    • Keep the hair dryer switched off and unplugged when not in use.
    • Avoid using extension cords to power your hair dryer. Since hair dryers require a high current draw, cheaper or old extension cords pose a greater fire risk.
    • Never heat a battery directly. If you're heating adhesive near or underneath a battery, make sure you've completely discharged the battery before applying heat.
  2. How to Use a Hair Dryer to Soften Adhesive, Set down the device: adım 2, 1 resimden 1.
    • The next four steps show how to use the hair dryer to soften strong adhesives, such as screen and frame adhesives.
    • Place your device on a clean, heat resistant surface or mat.
    • Keep flammable materials away from your work area.
  3. How to Use a Hair Dryer to Soften Adhesive, Turn on your hair dryer: adım 3, 3 resimden 1. How to Use a Hair Dryer to Soften Adhesive, Turn on your hair dryer: adım 3, 3 resimden 2. How to Use a Hair Dryer to Soften Adhesive, Turn on your hair dryer: adım 3, 3 resimden 3.
    • Set the temperature of your hair dryer to its "hot" setting.
    • Set the fan setting to "Low" for small parts, such as cables or tape.
    • Set the fan setting to "High" for large surfaces, such as screens or back covers.
  4. How to Use a Hair Dryer to Soften Adhesive, Soften the adhesive: adım 4, 3 resimden 1. How to Use a Hair Dryer to Soften Adhesive, Soften the adhesive: adım 4, 3 resimden 2. How to Use a Hair Dryer to Soften Adhesive, Soften the adhesive: adım 4, 3 resimden 3.
    • Position the nozzle of your hair dryer 2–3 inches above the device.
    • Move the hair dryer along the surface of your device.
    • Never leave your hair dryer in one spot for an extended period of time.
    • Heat the surface until it's hot to the touch, or as directed by the repair guide.
    • If you’re heating an OLED screen, don’t heat it over 176 °F (80 °C) or you may damage the OLED screen.
    • If you’re heating the adhesive underneath the battery, make sure the battery doesn’t go over 150 °F (66 °C) or you may damage the battery.
    • Make sure to turn off your hair dryer before setting it down to continue the repair.
  5. How to Use a Hair Dryer to Soften Adhesive: adım 5, 3 resimden 1. How to Use a Hair Dryer to Soften Adhesive: adım 5, 3 resimden 2. How to Use a Hair Dryer to Soften Adhesive: adım 5, 3 resimden 3.
    • Keep your hair dryer in motion while heating smaller surfaces by moving it in circles above the device.
    • Some components, such as large screens, require multiple cycles of heating and slicing. Take your time and apply more heat if the component feels stuck.
  6. How to Use a Hair Dryer to Soften Adhesive, Soften protective tape or film: adım 6, 2 resimden 1. How to Use a Hair Dryer to Soften Adhesive, Soften protective tape or film: adım 6, 2 resimden 2.
    • This step shows how to use your hair dryer to loosen protective tape and stickers.
    • Position the nozzle of your hair dryer 2–3 inches above the device and set the fan setting to "Low".
    • Apply heat in small circles over the tape or sticker for 30 seconds.
    • Peel the tape from the device.
  7. How to Use a Hair Dryer to Soften Adhesive, Soften cable adhesive: adım 7, 3 resimden 1. How to Use a Hair Dryer to Soften Adhesive, Soften cable adhesive: adım 7, 3 resimden 2. How to Use a Hair Dryer to Soften Adhesive, Soften cable adhesive: adım 7, 3 resimden 3.
    • This step shows how to use your hair dryer to loosen cables adhered to your device.
    • Apply heat in small circles over the cable for 30 seconds.
    • Peel the cable from the device.
  8. How to Use a Hair Dryer to Soften Adhesive, Turn off your hair dryer: adım 8, 2 resimden 1. How to Use a Hair Dryer to Soften Adhesive, Turn off your hair dryer: adım 8, 2 resimden 2.
    • Before continuing your repair, turn off your hair dryer and unplug it.
Sonuç
Allow the hair dryer to cool down before you store it.
For other general electronics skills guides, click here.
13 farklı kişi bu kılavuzu tamamladı.
Clay Eickemeyer
67.303 İtibar
453 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
136 Üyeler
17.430 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 46
Son 7 gün: 306
Son 30 gün: 1,334
Her zaman: 14,785
