Ana içeriğe geç
iMac Intel 27" EMC 2639 Adhesive Strips Replacement
Neye ihtiyacın var
  1. iMac Intel 27" EMC 2639 Adhesive Strips Replacement, Determine which adhesives you have: adım 1, 1 resimden 1.
    • Before you begin, make sure you have the right adhesive strips:
    • The 2012-2019 iMac adhesive strips have a microphone cutout and are numbered 16, 21, 22, 23, 25, and 26. They can be used on 27" iMacs from 2012-2019.
    • If your strips are numbered 11-16, follow the 2012-2015 iMac adhesive guide instead.
  2. iMac Intel 27" EMC 2639 Adhesive Strips Replacement, Stabilize the iMac: adım 2, 1 resimden 1.
    Bu adımda kullanılan alet:
    iMac Intel 27" Cardboard Service Wedge
    Satın Al
    • With the hinge free to move, the iMac will be unbalanced and hard to work on. Repairs can be completed as shown, but are faster and easier with an iFixit cardboard service wedge.
    • Follow these assembly directions to put the service wedge together.
    • If you are not using an iMac service wedge, be very careful when installing and working behind the display—it can easily fall out and break if the iMac moves unexpectedly.
  3. iMac Intel 27" EMC 2639 Adhesive Strips Replacement, Remove the old adhesive: adım 3, 2 resimden 1. iMac Intel 27" EMC 2639 Adhesive Strips Replacement, Remove the old adhesive: adım 3, 2 resimden 2.
    • Before you install new adhesive strips, remove all of the old adhesive from the perimeter of the rear enclosure.
    • If you are re-using your existing display, you must also remove the old adhesive from the back of the display.
    • Peel off the adhesive strips using tweezers or your fingers. Start at the bottom and peel upward towards the top of the device.
    • After all the old adhesive is removed, carefully clean the surface with 90% (or greater) isopropyl alcohol and a lint-free cloth. Wipe in one direction, not back and forth.
    • Don't skip this step, or your new adhesive strips may not bond properly, and the display may fall out of your iMac.
  4. iMac Intel 27" EMC 2639 Adhesive Strips Replacement, Lay out the adhesive strips: adım 4, 2 resimden 1. iMac Intel 27" EMC 2639 Adhesive Strips Replacement, Lay out the adhesive strips: adım 4, 2 resimden 2.
    • Lay out the adhesives strips beforehand so you won't accidentally install a strip in the wrong place:
    • Strip 22 on the top left
    • Strip 23 on the top right
    • Strip 21 on the right vertical
    • Strip 25 on the bottom right, dark side facing up.
    • Double check to make sure this strip has the necessary cutout for the microphone.
    • Strip 26 on the bottom left, dark side facing up
    • Strip 16 on the left vertical
  5. iMac Intel 27" EMC 2639 Adhesive Strips Replacement, Install the right side adhesive: adım 5, 3 resimden 1. iMac Intel 27" EMC 2639 Adhesive Strips Replacement, Install the right side adhesive: adım 5, 3 resimden 2. iMac Intel 27" EMC 2639 Adhesive Strips Replacement, Install the right side adhesive: adım 5, 3 resimden 3.
    • Start with strip 21, which goes on the right vertical edge of the iMac frame.
    • Before you peel off any backing, line the adhesive strip up along the frame of the iMac to get an idea of where it goes.
    • Peel the short piece of backing off the back of the strip.
  6. iMac Intel 27" EMC 2639 Adhesive Strips Replacement: adım 6, 2 resimden 1. iMac Intel 27" EMC 2639 Adhesive Strips Replacement: adım 6, 2 resimden 2.
    • Insert the tip of a spudger into the hole at the end of the strip where you just removed one layer of backing. Insert the spudger from the side that still has a layer of white backing on it.
  7. iMac Intel 27" EMC 2639 Adhesive Strips Replacement: adım 7, 3 resimden 1. iMac Intel 27" EMC 2639 Adhesive Strips Replacement: adım 7, 3 resimden 2. iMac Intel 27" EMC 2639 Adhesive Strips Replacement: adım 7, 3 resimden 3.
    • With the spudger still poking through the hole in the adhesive strip, push the spudger tip into the corresponding hole in the frame of the iMac.
    • Using the hole and spudger to anchor the position of the adhesive strip, line the strip up against the right edge, gently pull down against the spudger to ensure the strip is taut, and stick it onto the frame.
  8. iMac Intel 27" EMC 2639 Adhesive Strips Replacement: adım 8, 3 resimden 1. iMac Intel 27" EMC 2639 Adhesive Strips Replacement: adım 8, 3 resimden 2. iMac Intel 27" EMC 2639 Adhesive Strips Replacement: adım 8, 3 resimden 3.
    • Once you're satisfied that the top half of the adhesive strip is neatly aligned, peel longer blue piece of backing out from behind the strip.
    • If the top half isn't aligned properly, you can carefully peel it up and re-stick it before peeling off the lower backing strip. Be sure to use the spudger tip to anchor the top.
  9. iMac Intel 27" EMC 2639 Adhesive Strips Replacement: adım 9, 2 resimden 1. iMac Intel 27" EMC 2639 Adhesive Strips Replacement: adım 9, 2 resimden 2.
    • Align the lower portion of the strip with the right edge of the frame, and stick it down.
  10. iMac Intel 27" EMC 2639 Adhesive Strips Replacement: adım 10, 2 resimden 1. iMac Intel 27" EMC 2639 Adhesive Strips Replacement: adım 10, 2 resimden 2.
    • Use your finger to smooth out the strip. Make sure it is neatly aligned with the right side of the frame and that it sits flat.
    • Do not peel off the front adhesive backing yet.
  11. iMac Intel 27" EMC 2639 Adhesive Strips Replacement, Install the top and left adhesives: adım 11, 2 resimden 1. iMac Intel 27" EMC 2639 Adhesive Strips Replacement, Install the top and left adhesives: adım 11, 2 resimden 2.
    • Work your way counter-clockwise around the perimeter of the iMac, adding three more adhesive strips in the same manner:
    • Strip 16 on the vertical left
    • These three strips have a hole at each end—always use the smaller hole for alignment for more precise placement.
    • On the iMac Intel 27" Retina 5K Display, the top-right strip's blue tabs will not line up with the top antenna in the same way as the non-5K model. This is perfectly acceptable and won't impact the performance of the strips or antenna.
  12. iMac Intel 27" EMC 2639 Adhesive Strips Replacement, Install the bottom adhesives: adım 12, 1 resimden 1.
    • The next few steps will show you how to install the bottom right adhesive strip (strip 25), which includes a notch that must be aligned with the microphone.
    • Read through this step and the next four steps before you attempt the procedure.
    • Grasp the red pull tab on strip 25 and pull to separate about 2 inches (5 cm) of white backing from the strip.
  13. iMac Intel 27" EMC 2639 Adhesive Strips Replacement: adım 13, 3 resimden 1. iMac Intel 27" EMC 2639 Adhesive Strips Replacement: adım 13, 3 resimden 2. iMac Intel 27" EMC 2639 Adhesive Strips Replacement: adım 13, 3 resimden 3.
    • Fold the loose white backing to a right angle and pinch the crease with your fingers.
    • This exposes 2 inches of adhesive while folding the red tab out of the way.
  14. iMac Intel 27" EMC 2639 Adhesive Strips Replacement: adım 14, 3 resimden 1. iMac Intel 27" EMC 2639 Adhesive Strips Replacement: adım 14, 3 resimden 2. iMac Intel 27" EMC 2639 Adhesive Strips Replacement: adım 14, 3 resimden 3.
    • The microphone hole is the center hole flanked by two larger holes.
    • Align the adhesive strip to the bottom edge by positioning the microphone notch over the microphone hole.
    • If your iMac does not have a microphone hole, align the right end of the strip such that the L-bend sits next to the right vertical adhesive. The L-bend should not overlap the right vertical adhesive.
    • The adhesive tears easily. Be careful not to pull on the strip with too much force.
    • Once you have aligned the strip, carefully set the left exposed edge onto the iMac to secure the alignment.
  15. iMac Intel 27" EMC 2639 Adhesive Strips Replacement: adım 15, 3 resimden 1. iMac Intel 27" EMC 2639 Adhesive Strips Replacement: adım 15, 3 resimden 2. iMac Intel 27" EMC 2639 Adhesive Strips Replacement: adım 15, 3 resimden 3.
    • Peel away the white backing behind the strip to expose the remaining adhesive.
  16. iMac Intel 27" EMC 2639 Adhesive Strips Replacement: adım 16, 2 resimden 1. iMac Intel 27" EMC 2639 Adhesive Strips Replacement: adım 16, 2 resimden 2.
    • Run your finger from left to right along the length of the adhesive strip to ensure it is straight and unwrinkled, pressing down as you go to adhere the strip to the iMac.
  17. iMac Intel 27" EMC 2639 Adhesive Strips Replacement: adım 17, 3 resimden 1. iMac Intel 27" EMC 2639 Adhesive Strips Replacement: adım 17, 3 resimden 2. iMac Intel 27" EMC 2639 Adhesive Strips Replacement: adım 17, 3 resimden 3.
    • Repeat the previous steps for the bottom left adhesive strip (strip 26), aligning and placing it along the bottom left edge of the iMac.
    • The strip should be positioned such that the L-bend sits next to the left vertical adhesive. The L-bend should not overlap the left vertical adhesive.
    • Once you've applied all the adhesive strips, the iMac should look as shown in the second photo.
  18. iMac Intel 27" EMC 2639 Adhesive Strips Replacement, Replace the display: adım 18, 2 resimden 1. iMac Intel 27" EMC 2639 Adhesive Strips Replacement, Replace the display: adım 18, 2 resimden 2.
    • Gently set the display in place over the iMac and align it carefully.
  19. iMac Intel 27" EMC 2639 Adhesive Strips Replacement: adım 19, 2 resimden 1. iMac Intel 27" EMC 2639 Adhesive Strips Replacement: adım 19, 2 resimden 2.
    • Use painter's tape or masking tape to temporarily secure the bottom edge of the display to the iMac's enclosure.
    • The tape preserves the display's alignment, and allows you to safely swing the top edge of the display open to access the display cables.
  20. iMac Intel 27" EMC 2639 Adhesive Strips Replacement, Test your repair: adım 20, 3 resimden 1. iMac Intel 27" EMC 2639 Adhesive Strips Replacement, Test your repair: adım 20, 3 resimden 2. iMac Intel 27" EMC 2639 Adhesive Strips Replacement, Test your repair: adım 20, 3 resimden 3.
    • At this point it's a good idea to test your repair, in order to make sure your iMac works properly before you seal it back up. Follow the next three steps to temporarily reconnect the display cables and boot up your iMac prior to pulling the protective film off the adhesive strips.
    • If you've already verified that your iMac is working correctly and are ready to seal it up, skip to step 22.
    • Gently insert the display data connector into its socket on the logic board. Be sure to press it straight into the socket, and insert it completely.
    • Flip the display data connector lock down onto the socket.
    • Insert the display power connector into its socket on the logic board.
  21. iMac Intel 27" EMC 2639 Adhesive Strips Replacement: adım 21, 2 resimden 1. iMac Intel 27" EMC 2639 Adhesive Strips Replacement: adım 21, 2 resimden 2.
    • Set the display back on the iMac's rear enclosure.
    • At this time, plug in your iMac, power it on, and test your repair before sealing up the computer. Be sure to check for full functionality of any hardware you removed or disconnected.
    • When you are finished, shut the iMac down and unplug the power cord before you continue.
  22. iMac Intel 27" EMC 2639 Adhesive Strips Replacement, Seal the iMac: adım 22, 3 resimden 1. iMac Intel 27" EMC 2639 Adhesive Strips Replacement, Seal the iMac: adım 22, 3 resimden 2. iMac Intel 27" EMC 2639 Adhesive Strips Replacement, Seal the iMac: adım 22, 3 resimden 3.
    • Verify that your iMac is turned off and unplugged from power before you continue.
    • After confirming that your iMac functions properly, disconnect the display cables and carefully lean the display forward.
    • Remove the film from the two bottom strips by reaching in from above with a pair of tweezers and pulling the blue tabs straight up from the bottom edge of the display.
  23. iMac Intel 27" EMC 2639 Adhesive Strips Replacement: adım 23, 3 resimden 1. iMac Intel 27" EMC 2639 Adhesive Strips Replacement: adım 23, 3 resimden 2. iMac Intel 27" EMC 2639 Adhesive Strips Replacement: adım 23, 3 resimden 3.
    • Reconnect the display power and data cables for the final time.
    • Remember to secure the metal retaining bracket on the display data cable.
  24. iMac Intel 27" EMC 2639 Adhesive Strips Replacement: adım 24, 3 resimden 1. iMac Intel 27" EMC 2639 Adhesive Strips Replacement: adım 24, 3 resimden 2. iMac Intel 27" EMC 2639 Adhesive Strips Replacement: adım 24, 3 resimden 3.
    Microfiber Cleaning Cloths
    $3.99
    Satın Al
    • Check the glass directly in front of the webcam for dust and other contaminants. If necessary, wipe it down with a microfiber cloth before you seal up the display.
    • Steady the display with one hand as you remove the protective film in the following steps, or rest it lightly against the iMac's enclosure.
  25. iMac Intel 27" EMC 2639 Adhesive Strips Replacement: adım 25, 3 resimden 1. iMac Intel 27" EMC 2639 Adhesive Strips Replacement: adım 25, 3 resimden 2. iMac Intel 27" EMC 2639 Adhesive Strips Replacement: adım 25, 3 resimden 3.
    • Remove one side of the protective film from the top left strip by pulling its tab straight up.
  26. iMac Intel 27" EMC 2639 Adhesive Strips Replacement: adım 26, 2 resimden 1. iMac Intel 27" EMC 2639 Adhesive Strips Replacement: adım 26, 2 resimden 2.
    • Remove the other side of the protective film from the top left strip.
  27. iMac Intel 27" EMC 2639 Adhesive Strips Replacement: adım 27, 2 resimden 1. iMac Intel 27" EMC 2639 Adhesive Strips Replacement: adım 27, 2 resimden 2.
    • Repeat the previous steps to remove the protective films from all the remaining adhesive strips.
  28. iMac Intel 27" EMC 2639 Adhesive Strips Replacement: adım 28, 2 resimden 1. iMac Intel 27" EMC 2639 Adhesive Strips Replacement: adım 28, 2 resimden 2.
    • To ensure a strong bond, carefully tip the iMac flat on its back (with the screen facing straight up) and press carefully but firmly around all four edges of the display.
    • Remove the tape securing the display to the rear enclosure.
    • Check the display after 24 hours to make sure that it is not loose on the iMac.
Bitiş Çizgisi
103 farklı kişi bu kılavuzu tamamladı.
Andrew Optimus Goldheart
502.807 İtibar
407 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
135 Üyeler
16.767 adet Kılavuz yazıldı
5 Yorum
Is there any reason to believe that Apple would deny any warranty repairs due to these adhesive strips not being identical to Apple's? I'd like to open and clean my iMac before taking it in to have the display replaced under warranty, but the vibes I'm getting from Apple support suggest that Apple may deny me service if the adhesive strips 'show any signs of tampering', i.e., being replaced for any reason. This sounds silly to me, as it doesn't void Apple's warranty to upgrade my hard drive.
gibsonjont - Yanıt
<<<crickets>>>
gibsonjont - Yanıt
Unfortunately, these strips are not even close to the original ones. Has anyone tried to reopen the iMac with these strips in place? A real pain… The original one must have a sort of foam in-between so that one can cut through with the ifixit wheel or a knife. After that, it is easy to remove the adhesive swipes on both sides. Trying to reopen an iMac with the iFixit strips in place is really hard and impossible with the iFixit wheel. Sad…
rozakis - Yanıt
True ! Same goes with OWC’s strips : no foam.
The only way to reopen the iMac should it be needed, is to use razor blades…
José -
Clear tuto, I did it on several IMac, the first time was a discovery… than it became easier on the following, as usual the best is to take your time and follow the instructions which are very clear
Ivan Corbet - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 8
Son 7 gün: 45
Son 30 gün: 192
Her zaman: 42,862
