<?xml version="1.0" encoding="utf-8"?>
<rss version="2.0"
           xmlns:content="http://purl.org/rss/1.0/modules/content/"
           xmlns:wfw="http://wellformedweb.org/CommentAPI/"
<channel>
<title><![CDATA[iFixit - Answers With Device &quot;Jump Starter Power Station&quot;]]></title>
<link>https://tr.ifixit.com/Answers/Device/Jump_Starter_Power_Station/All?rss=yes</link>
<description><![CDATA[Top Questions according to your query. Only showing &quot;Jump Starter Power Station&quot; questions.]]></description>
<language>en-US</language>
<pubDate>Tue, 18 Aug 2026 00:06:21 -0700</pubDate>
<item>
<title><![CDATA[Jump Starter Power Station: Tire inflator turns on but will not inflate]]></title>
<description><![CDATA[<p>Tire inflator will turn on but won’t inflate</p>
<p>⟐ Commented Mart 07, 2026 at 17:15 GMT-7</p>]]></description>
<link>https://tr.ifixit.com/Answers/View/943728/Tire+inflator+turns+on+but+will+not+inflate</link>
<guid isPermaLink="false" >https://tr.ifixit.com/Answers/View/943728</guid>
<pubDate>Sat, 07 Mar 2026 17:15:54 -0700</pubDate>
</item>
<item>
<title><![CDATA[Jump Starter Power Station: Why is my rescue 900 jump starter not charging]]></title>
<description><![CDATA[<p>Green light saying fully charged when My jump starter is plugged in but its dead..will not charge</p>
<p>⟐ Commented Kasım 20, 2025 at 5:16 GMT-7</p>]]></description>
<link>https://tr.ifixit.com/Answers/View/626816/Why+is+my+rescue+900+jump+starter+not+charging</link>
<guid isPermaLink="false" >https://tr.ifixit.com/Answers/View/626816</guid>
<pubDate>Thu, 20 Nov 2025 05:16:18 -0700</pubDate>
</item>
<item>
<title><![CDATA[Jump Starter Power Station: Can a regular jump starter battery charger be used as a 12v power sup]]></title>
<description><![CDATA[<p>Can a jump starter be used as a 12v power supply?</p>
<p>⟐ Commented Aralık 13, 2024 at 4:08 GMT-7</p>]]></description>
<link>https://tr.ifixit.com/Answers/View/567287/Can+a+regular+jump+starter+battery+charger+be+used+as+a+12v+power+sup</link>
<guid isPermaLink="false" >https://tr.ifixit.com/Answers/View/567287</guid>
<pubDate>Fri, 13 Dec 2024 04:08:41 -0700</pubDate>
</item>
<item>
<title><![CDATA[Jump Starter Power Station: 12 volt Viking jump starter]]></title>
<description><![CDATA[<p>It should be changed but it keeps beeping and says that the battery is dead on the jump starter. What should I do?</p>
<p>⟐ Commented Ağustos 29, 2024 at 19:01 GMT-7</p>]]></description>
<link>https://tr.ifixit.com/Answers/View/866839/12+volt+Viking+jump+starter</link>
<guid isPermaLink="false" >https://tr.ifixit.com/Answers/View/866839</guid>
<pubDate>Thu, 29 Aug 2024 19:01:12 -0700</pubDate>
</item>
<item>
<title><![CDATA[Jump Starter Power Station: ac adapter lost need replacement]]></title>
<description><![CDATA[<p>misplaced my ac adapter what input and output should I use to recharge example</p>
<p>input ac120v  60hz</p>
<p>output dc12v 500ma</p>
<p>what should I buy</p>
<div class="clearer"></div><div class="headerContainer"><h3 id="Section_Update_02_02_Num_2016" class="header">Update (02/02/2016)</h3></div>
<p>I need to buy an ac/dc adapter, an extension cord is not going to do the trick. I need to know what kind on voltage and output I need. The converter/adapter is lost . I would like to save the unit but do not know what size adapter to buy</p>
<div class="clearer"></div><div class="headerContainer"><h3 id="Section_Update_02_02_Num_2016_1" class="header">Update (02/02/2016)</h3></div>
<p>This a battery jump pack that is used to jump start a car.  Some units have an ac adapter built in so you can charge the battery in the jump start pack.  My unit has a spot to connect the ac adapter to the jump pack so you can charge the battery in the jump pack.  My ac adapter has been lost.  I know I have to buy a new ac adapter so I can charge my jump pack, what I do not know is if the input (from the ac adapter) is 120v 60 hz</p>
<p>I understand that the DC output needs to dc12v.  I do not understand the milliamps.  The battery in the jump box is 12v 10 ah ( what ever that is).  I just want a new ac adapter to charge the jump pack with that is not going to damage anything.</p>
<p>⟐ Commented Haziran 18, 2024 at 10:44 GMT-7</p>]]></description>
<link>https://tr.ifixit.com/Answers/View/287564/ac+adapter+lost+need+replacement</link>
<guid isPermaLink="false" >https://tr.ifixit.com/Answers/View/287564</guid>
<pubDate>Tue, 18 Jun 2024 10:44:13 -0700</pubDate>
</item>
<item>
<title><![CDATA[Jump Starter Power Station: The tire inflater the compressor doesn’t turn on.]]></title>
<description><![CDATA[<p>I’ve owned one for two years and never used it. I’ve charged it for four straight days and when I try the tire inflater the compressor doesn’t turn on. The charger and light only work when I leave it plugged in. Any ideas?</p>
<p>⟐ Commented Şubat 01, 2024 at 8:54 GMT-7</p>]]></description>
<link>https://tr.ifixit.com/Answers/View/670303/The+tire+inflater+the+compressor+doesn%E2%80%99t+turn+on.</link>
<guid isPermaLink="false" >https://tr.ifixit.com/Answers/View/670303</guid>
<pubDate>Thu, 01 Feb 2024 08:54:00 -0700</pubDate>
</item>
<item>
<title><![CDATA[Jump Starter Power Station: Model PSX3 tire inflator won't turn on, other functions have power]]></title>
<description><![CDATA[<p>PowerStation model PSX3 has both tire inflator and jump starter functions.  It also has a work light.  The inflator had been working fine, but now the push button switch has no effect.  Seems as if an electrical connection has been broken. The work light functions perfectly, so there is power available.   Inspection of the interior wiring didn’t reveal anything obvious.</p>
<p>⟐ Commented Nisan 23, 2023 at 10:34 GMT-7</p>]]></description>
<link>https://tr.ifixit.com/Answers/View/525866/Model+PSX3+tire+inflator+won&#039;t+turn+on,+other+functions+have+power</link>
<guid isPermaLink="false" >https://tr.ifixit.com/Answers/View/525866</guid>
<pubDate>Sun, 23 Apr 2023 10:34:43 -0700</pubDate>
</item>
<item>
<title><![CDATA[Jump Starter Power Station: What can I substitute to charge this with]]></title>
<description><![CDATA[<p>I lost the original device charger it's DC15v input/3.2A &amp; 12 v output &amp; looks like says 5.? Not sure can't read it  then like 13.1A what can I use to charge this with as a substitute and how much higher is safe for the device n how much lower is enough to do so</p>
<p>⟐ Edited Nisan 06, 2023 at 16:50 GMT-7</p>]]></description>
<link>https://tr.ifixit.com/Answers/View/776985/What+can+I+substitute+to+charge+this+with</link>
<guid isPermaLink="false" >https://tr.ifixit.com/Answers/View/776985</guid>
<pubDate>Thu, 06 Apr 2023 16:50:23 -0700</pubDate>
</item>
<item>
<title><![CDATA[Jump Starter Power Station: My charger port is broken can it be fixed?]]></title>
<description><![CDATA[<p>My charger port is broken can it be replaced</p>]]></description>
<link>https://tr.ifixit.com/Answers/View/773340/My+charger+port+is+broken+can+it+be+fixed</link>
<guid isPermaLink="false" >https://tr.ifixit.com/Answers/View/773340</guid>
<pubDate>Sun, 12 Mar 2023 08:08:50 -0700</pubDate>
</item>
<item>
<title><![CDATA[Jump Starter Power Station: How to repair broken jumper pack]]></title>
<description><![CDATA[<p>I have a basic car jumper pack. The solder connection of one of the rectifiers broke.</p>
<p>I can resolder but don't know where it's meant to connect to.</p>
<p>The soldering looks wrong to me. It doesn't make sense to have components hanging off the side of the board.</p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/T2bFqxfSXEIhEfAF.standard" width="169" height="225" class="hasMenu hasLarge" alt="Resim" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/T2bFqxfSXEIhEfAF.huge&quot;, '', 'width=900,height=1200')" /></div>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/QXLlAj4UYGoCCvbs.standard" width="169" height="225" class="hasMenu hasLarge" alt="Resim" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/QXLlAj4UYGoCCvbs.huge&quot;, '', 'width=900,height=1200')" /></div>
<div class="clearer"></div><div class="headerContainer"><h3 id="Section_Update_01_03_Num_2023" class="header">Update (01/03/2023)</h3></div>
<p>I found it how it should be</p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/CQV5xxYcNaQGIZZt.standard" width="127" height="225" class="hasMenu hasLarge" alt="Resim" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/CQV5xxYcNaQGIZZt.full&quot;, '', 'width=1134,height=2016')" /></div>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/TOCxXUUgHgES3IuZ.standard" width="127" height="225" class="hasMenu hasLarge" alt="Resim" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/TOCxXUUgHgES3IuZ.full&quot;, '', 'width=1134,height=2016')" /></div>
<p>⟐ Edited by author Ocak 03, 2023 at 1:01 GMT-7</p>]]></description>
<link>https://tr.ifixit.com/Answers/View/762345/How+to+repair+broken+jumper+pack</link>
<guid isPermaLink="false" >https://tr.ifixit.com/Answers/View/762345</guid>
<pubDate>Tue, 03 Jan 2023 01:01:53 -0700</pubDate>
</item>
<item>
<title><![CDATA[Jump Starter Power Station: Duralast 700 peak amp turned to a lithium battery charger?]]></title>
<description><![CDATA[<p>So I bought a Duralast 700 peak amp jumper pack actually two of them and both just died throw out the first one and the second one I kept around and was thinking if there is a way turn it into a battery charger for my Ryobi 18v batteries bought them I'm a yard sale but didn't come with a charger so I wanted to know thank you all.</p>
<p>⟐ Answered Mart 14, 2022 at 15:20 GMT-7</p>]]></description>
<link>https://tr.ifixit.com/Answers/View/612818/Duralast+700+peak+amp+turned+to+a+lithium+battery+charger</link>
<guid isPermaLink="false" >https://tr.ifixit.com/Answers/View/612818</guid>
<pubDate>Mon, 14 Mar 2022 15:20:51 -0700</pubDate>
</item>
<item>
<title><![CDATA[Jump Starter Power Station: on charge clock not moving also red charge light not coming flash]]></title>
<description><![CDATA[<p>Hi.</p>
<p>I have a new   Top Tech 3 in1 12Ah Booster Jump Pack with Tyre inflator.</p>
<p>It was working and battery nearly full.</p>
<p>I used the light awhile and  tried put back to on charge and worked. I was tried change the cable different way but a little light came on when I plug the charge cable on jumper connection and red light didn’t come on and looks like not charge anymore.</p>
<p>I think something fail when I plug in 2nd time.</p>
<p>Battery screen working and show nearly half battery but on charge clock not moving also red charge light not coming flash.</p>
<p>What do you think broken  please?</p>
<p>⟐ Edited Ekim 27, 2021 at 12:32 GMT-7</p>]]></description>
<link>https://tr.ifixit.com/Answers/View/710221/on+charge+clock+not+moving+also+red+charge+light+not+coming+flash</link>
<guid isPermaLink="false" >https://tr.ifixit.com/Answers/View/710221</guid>
<pubDate>Wed, 27 Oct 2021 12:32:49 -0700</pubDate>
</item>
<item>
<title><![CDATA[Jump Starter Power Station: Vector Veco 10s I don't have a car charger or plug]]></title>
<description><![CDATA[<p>I have a 300 amps vector 12 volt DC. But I don't have a car charger or plug how and where can I get one it's model veco10s 5 second 225 amps dc can you help me fine a</p>
<p>⟐ Answered Haziran 23, 2020 at 22:15 GMT-7</p>]]></description>
<link>https://tr.ifixit.com/Answers/View/642651/Vector+Veco+10s+I+don&#039;t+have+a+car+charger+or+plug</link>
<guid isPermaLink="false" >https://tr.ifixit.com/Answers/View/642651</guid>
<pubDate>Tue, 23 Jun 2020 22:15:28 -0700</pubDate>
</item>
<item>
<title><![CDATA[Jump Starter Power Station: The air compressor does not work. The power station battery is dead.]]></title>
<description><![CDATA[<p>The air compressor in the PS 1100 Power Station does not operate when plugged in to a wall socket.</p>
<p>⟐ Commented Ocak 17, 2019 at 6:28 GMT-7</p>]]></description>
<link>https://tr.ifixit.com/Answers/View/240865/The+air+compressor+does+not+work.+The+power+station+battery+is+dead.</link>
<guid isPermaLink="false" >https://tr.ifixit.com/Answers/View/240865</guid>
<pubDate>Thu, 17 Jan 2019 06:28:08 -0700</pubDate>
</item>
<item>
<title><![CDATA[Jump Starter Power Station: The air compresser does not work]]></title>
<description><![CDATA[<p>the air compresser does not work</p>
<p>⟐ Edited Ekim 10, 2018 at 1:03 GMT-7</p>]]></description>
<link>https://tr.ifixit.com/Answers/View/521418/The+air+compresser+does+not+work</link>
<guid isPermaLink="false" >https://tr.ifixit.com/Answers/View/521418</guid>
<pubDate>Wed, 10 Oct 2018 01:03:35 -0700</pubDate>
</item>
<item>
<title><![CDATA[Jump Starter Power Station: charge in car with inverter]]></title>
<description><![CDATA[<p>Is there any reason a driver with a jump starter power station could not use an inexpensive (read modified sign wave) inverter to keep a jump starter topped off. Mostly I need to know to use this to power a CPAP. I know this will use more power than a straight cable, but the indicator lights work with AC</p>
<p>Thanks</p>
<p>⟐ Answer accepted Eylül 08, 2018 at 6:36 GMT-7</p>]]></description>
<link>https://tr.ifixit.com/Answers/View/203465/charge+in+car+with+inverter</link>
<guid isPermaLink="false" >https://tr.ifixit.com/Answers/View/203465</guid>
<pubDate>Sat, 08 Sep 2018 06:36:47 -0700</pubDate>
</item>
<item>
<title><![CDATA[Jump Starter Power Station: VEC01POB Jump Starter Assembly]]></title>
<description><![CDATA[<p>I tore down my jumper to replace the battery, but I dont know how to assemble the wires back since there are many, can anyone help? model is VEC012POB.</p>
<p>⟐ Commented Eylül 07, 2018 at 19:56 GMT-7</p>]]></description>
<link>https://tr.ifixit.com/Answers/View/514261/VEC01POB+Jump+Starter+Assembly</link>
<guid isPermaLink="false" >https://tr.ifixit.com/Answers/View/514261</guid>
<pubDate>Fri, 07 Sep 2018 19:56:55 -0700</pubDate>
</item>
<item>
<title><![CDATA[Jump Starter Power Station: Power station won’t charge]]></title>
<description><![CDATA[<p>My roadmaster power station will not take a charge what can I do about this</p>]]></description>
<link>https://tr.ifixit.com/Answers/View/512264/Power+station+won%E2%80%99t+charge</link>
<guid isPermaLink="false" >https://tr.ifixit.com/Answers/View/512264</guid>
<pubDate>Wed, 29 Aug 2018 07:41:52 -0700</pubDate>
</item>
<item>
<title><![CDATA[Jump Starter Power Station: Road master power station]]></title>
<description><![CDATA[<p>I have a roadmaster power station it is been in my trunk dry and not exposed to the weather and went to go use it and the battery is dead I tried to plug it into the AC outlet and it does not charge what can I do</p>
<p>⟐ Answered Ağustos 28, 2018 at 19:33 GMT-7</p>]]></description>
<link>https://tr.ifixit.com/Answers/View/512103/Road+master+power+station</link>
<guid isPermaLink="false" >https://tr.ifixit.com/Answers/View/512103</guid>
<pubDate>Tue, 28 Aug 2018 19:33:07 -0700</pubDate>
</item>
<item>
<title><![CDATA[Jump Starter Power Station: Lost A/C cord.Will 16 ga extension work?]]></title>
<description><![CDATA[<p>Will a standard extension cord work for Power Station PS1100 to recharge?</p>
<p>⟐ Answer accepted Nisan 02, 2018 at 6:50 GMT-7</p>]]></description>
<link>https://tr.ifixit.com/Answers/View/112578/Lost+A-C+cord.Will+16+ga+extension+work</link>
<guid isPermaLink="false" >https://tr.ifixit.com/Answers/View/112578</guid>
<pubDate>Mon, 02 Apr 2018 06:50:02 -0700</pubDate>
</item>
</channel>
</rss>
