<?xml version="1.0" encoding="utf-8"?>
<rss version="2.0"
           xmlns:content="http://purl.org/rss/1.0/modules/content/"
           xmlns:wfw="http://wellformedweb.org/CommentAPI/"
<channel>
<title><![CDATA[iFixit - Answers With Device &quot;Milwaukee Power Drill&quot;]]></title>
<link>https://tr.ifixit.com/Answers/Device/Milwaukee_Power_Drill?rss=yes</link>
<description><![CDATA[Top Questions according to your query. Only showing &quot;Milwaukee Power Drill&quot; questions.]]></description>
<language>en-US</language>
<pubDate>Mon, 17 Aug 2026 13:03:09 -0700</pubDate>
<item>
<title><![CDATA[Milwaukee M12 2407-20: Drill works until it has had moderate use, then dies]]></title>
<description><![CDATA[<p>Drill is 5 years old, had moderate use. Drill 5 to 10 holes in wood or drive 5 to 10 longer screws and the drill stops working, battery strength lights flash.  Leave it alone for 3 to 5 minutes and it works again normally. Do the same amount of work and it repeats. If you only drill 1 or 2 holes or drive 1 or 2 screws the drill does not misbehave.  A tool only replacement is $100 CDN and an upgrade to 1/2” is only $30 more with charger and bag. The repair solution needs to be inexpensive parts wise and not epic to perform. I’m willing to try a fairly simple repair/servicing.  Any suggestions??</p>
<p>⟐ Answer accepted Haziran 20, 2024 at 22:20 GMT-7</p>]]></description>
<link>https://tr.ifixit.com/Answers/View/712712/Drill+works+until+it+has+had+moderate+use,+then+dies</link>
<guid isPermaLink="false" >https://tr.ifixit.com/Answers/View/712712</guid>
<pubDate>Thu, 20 Jun 2024 22:20:37 -0700</pubDate>
</item>
<item>
<title><![CDATA[Milwaukee M12 2407-20: Milwaukee drill light stays on no power,]]></title>
<description><![CDATA[<p>my Milwaukee drill 2407 fully charged battery light stays on, but no power power to the drill itself. Why would then what would be making this happen? Batteries are fully charged</p>
<p>⟐ Edited Haziran 23, 2025 at 21:34 GMT-7</p>]]></description>
<link>https://tr.ifixit.com/Answers/View/843663/Milwaukee+drill+light+stays+on+no+power,</link>
<guid isPermaLink="false" >https://tr.ifixit.com/Answers/View/843663</guid>
<pubDate>Mon, 23 Jun 2025 21:34:04 -0700</pubDate>
</item>
<item>
<title><![CDATA[Milwaukee M18 2606-20: Gear box reassembly - chuck spins very slowly]]></title>
<description><![CDATA[<p>Hey all,</p>
<p>I picked up and old used cordless drill ( model # 2606-20, 18v 1/2&quot; driver).  It was essentially free, part of a small lot of drills I bought for cheap.  So I wanted to clean it up, see if it worked (it didn't have a battery), etc.</p>
<p>I found a battery and confirmed that it did work.  Generally it all seemed decent - at least functional.</p>
<p>I took it apart, cleaned up various things... including disassembling much of the gear box section (not all of it, but say 2/3).  When I reassembled things... and figured out that the magnet ring was backwards :) ...  I tried it out.  The motor spun, the shaft spun... but the chuck was spinning very slowly.  Like I had turned a gear increaser into a reducer.  So say 10-20 RPM instead of... ~450.</p>
<p>So I took it all apart again, this time disassembling the entire gear box and including the chuck assembly... put it back together - still turns very slowly.</p>
<p>I have reviewed various disassembly videos and some assembly diagrams... I think I'm doing it right.</p>
<p>I know it can be really hard to troubleshooting something like this without seeing it, without really knowing what I did...  I'm pretty handy with tools and things (spent 15 years working as a maintenance technician in a wafer fab) - so not a complete noob.  But nearly always the first time you do something it's not perfect - I'm missing something here, obviously.  :)</p>
<p>Anybody have any thoughts about what I messed up?</p>
<p>⟐ Commented Mayıs 30, 2025 at 7:20 GMT-7</p>]]></description>
<link>https://tr.ifixit.com/Answers/View/901945/Gear+box+reassembly+-+chuck+spins+very+slowly</link>
<guid isPermaLink="false" >https://tr.ifixit.com/Answers/View/901945</guid>
<pubDate>Fri, 30 May 2025 07:20:01 -0700</pubDate>
</item>
<item>
<title><![CDATA[Milwaukee Hole Shooter 02441  664C 2014: Trying to repair power cable]]></title>
<description><![CDATA[<p>Trying to figure out how to take the triple prong off so I can replace the cable</p>
<p>⟐ Answer edited Haziran 27, 2024 at 15:35 GMT-7</p>]]></description>
<link>https://tr.ifixit.com/Answers/View/856847/Trying+to+repair+power+cable</link>
<guid isPermaLink="false" >https://tr.ifixit.com/Answers/View/856847</guid>
<pubDate>Thu, 27 Jun 2024 15:35:35 -0700</pubDate>
</item>
<item>
<title><![CDATA[Milwaukee Drill Driver 276020  H16A 2017: it will not turn the screw the screw under pressure/ t]]></title>
<description><![CDATA[<p>the driver will not turn a screw under a load but will rotate freely with no load</p>]]></description>
<link>https://tr.ifixit.com/Answers/View/833551/it+will+not+turn+the+screw+the+screw+under+pressure-+t</link>
<guid isPermaLink="false" >https://tr.ifixit.com/Answers/View/833551</guid>
<pubDate>Tue, 23 Jan 2024 14:05:08 -0700</pubDate>
</item>
</channel>
</rss>
