<?xml version="1.0" encoding="utf-8"?>
<rss version="2.0"
           xmlns:content="http://purl.org/rss/1.0/modules/content/"
           xmlns:wfw="http://wellformedweb.org/CommentAPI/"
<channel>
<title><![CDATA[iFixit - Answers With Device &quot;Other Brand Angle Grinder&quot;]]></title>
<link>https://tr.ifixit.com/Answers/Device/Other_Brand_Angle_Grinder?rss=yes</link>
<description><![CDATA[Top Questions according to your query. Only showing &quot;Other Brand Angle Grinder&quot; questions.]]></description>
<language>en-US</language>
<pubDate>Sun, 09 Aug 2026 02:23:30 -0700</pubDate>
<item>
<title><![CDATA[Porter-Cable PC60TAG: Why is my grinder overheating?]]></title>
<description><![CDATA[<p>Recently when i use my grinder, it begins to get very hot after a short period of use. This does not seem normal, could you offer any suggestions to remedy this?</p>
<p>⟐ Answer deleted Mayıs 29, 2020 at 2:46 GMT-7</p>]]></description>
<link>https://tr.ifixit.com/Answers/View/308624/Why+is+my+grinder+overheating</link>
<guid isPermaLink="false" >https://tr.ifixit.com/Answers/View/308624</guid>
<pubDate>Fri, 29 May 2020 02:46:48 -0700</pubDate>
</item>
<item>
<title><![CDATA[Other Brand Angle Grinder: How can I reduce the rpm of my grinder?]]></title>
<description><![CDATA[<p>How can I reduce the rpm of my grinder?</p>
<p>⟐ Commented Mart 24, 2026 at 1:58 GMT-7</p>]]></description>
<link>https://tr.ifixit.com/Answers/View/943633/How+can+I+reduce+the+rpm+of+my+grinder</link>
<guid isPermaLink="false" >https://tr.ifixit.com/Answers/View/943633</guid>
<pubDate>Tue, 24 Mar 2026 01:58:03 -0700</pubDate>
</item>
<item>
<title><![CDATA[Porter-Cable PC60TAG: Why won't my angle grinder turn on when plugged in?]]></title>
<description><![CDATA[<p>When my angle grinder is plugged in, flipping the power switch has no effect.</p>
<p>⟐ Answered Nisan 04, 2023 at 2:46 GMT-7</p>]]></description>
<link>https://tr.ifixit.com/Answers/View/303250/Why+won&#039;t+my+angle+grinder+turn+on+when+plugged+in</link>
<guid isPermaLink="false" >https://tr.ifixit.com/Answers/View/303250</guid>
<pubDate>Tue, 04 Apr 2023 02:46:32 -0700</pubDate>
</item>
<item>
<title><![CDATA[Bauker PGA115G1.2 Angle grinder: Kenapa gerinda berbunyi kasar dan tidak berputar?]]></title>
<description><![CDATA[<p>Gerinda saya berbunyi kasar dan tidak berputar</p>
<p>⟐ Answer edited Haziran 23, 2024 at 7:55 GMT-7</p>]]></description>
<link>https://tr.ifixit.com/Answers/View/856174/Kenapa+gerinda+berbunyi+kasar+dan+tidak+berputar</link>
<guid isPermaLink="false" >https://tr.ifixit.com/Answers/View/856174</guid>
<pubDate>Sun, 23 Jun 2024 07:55:51 -0700</pubDate>
</item>
<item>
<title><![CDATA[Porter-Cable PC60TAG: Why wont my Porter-Cable PC60TAG angle grinder not turn off?]]></title>
<description><![CDATA[<p>No matter what position (on / off) you slide the power switch to the grinder will not turn off.  I have to unplug it.</p>
<p>⟐ Commented Temmuz 02, 2022 at 19:48 GMT-7</p>]]></description>
<link>https://tr.ifixit.com/Answers/View/737456/Why+wont+my+Porter-Cable+PC60TAG+angle+grinder+not+turn+off</link>
<guid isPermaLink="false" >https://tr.ifixit.com/Answers/View/737456</guid>
<pubDate>Sat, 02 Jul 2022 19:48:22 -0700</pubDate>
</item>
<item>
<title><![CDATA[Other Brand Angle Grinder: Lead shift ,Rewinding 24 bar 12 slot armature]]></title>
<description><![CDATA[<p>I am rewinding an armature for an old-model metal-bodied Chinese mini angle grinder (approx. 700W-850W, 11,000-12,000 RPM).</p>
<p>Technical Specs:</p>
<p>- Core: 12 slots, 24 commutator bars.</p>
<p>- Dimensions: Core length 55mm, diameter 3.2cm.</p>
<p>- Wire: 32 AWG (0.20mm).</p>
<p>- Winding: Factory was 22 turns/coil (88 wires/slot total), but I plan to use 23 turns/coil (92 wires/slot) to improve torque and heat management.</p>
<p>- Pitch: 1 to 6.</p>
<p>- Progression: Retrogressive (1 -&gt; 24 -&gt; 23).</p>
<p>- Brushes: Positioned 90 degrees from the stator coils.</p>
<p>- Potting: Using two-part submersible pump epoxy (thinned with heat) in a vertical gravity-pour method.</p>
<p>The specific question is about the Lead Shift:</p>
<p>Because I am adding an extra turn (23 instead of 22) and the brushes are at 90 degrees, which lead shift is best to handle the high RPM and field twist?</p>
<p>1. Zero Shift (Bar 1 directly in center of Slot 1).</p>
<p>2. 7.5 Degree Shift (Mica directly in center of Slot 1).</p>
<p>3. 15 Degree Shift (Bar 24, one bar left, in center of Slot 1).</p>
<p>I am leaning toward the 7.5° (Mica Center) shift as a balance, but I'm worried about &quot;fire-ringing&quot; at 11,000 RPM. Has anyone done this specific 23-turn mod on these 12/24 armatures?</p>
<p>By ibot guess, the magnetic shift will ne around 18degree. I can't retrieve any original data of lead shift but from one saved coil, i get continuity from bar24 and 23, assuming first bar in center of slot is bar 1 and winding is retrogressive, connections moving left.</p>]]></description>
<link>https://tr.ifixit.com/Answers/View/950662/Lead+shift+,Rewinding+24+bar+12+slot+armature</link>
<guid isPermaLink="false" >https://tr.ifixit.com/Answers/View/950662</guid>
<pubDate>Thu, 16 Apr 2026 05:30:06 -0700</pubDate>
</item>
<item>
<title><![CDATA[Porter-Cable PC60TAG: Why can I not lock wheel to take off wheel]]></title>
<description><![CDATA[<p>I cannot lock hub t replace or take off grinding wheel</p>]]></description>
<link>https://tr.ifixit.com/Answers/View/331865/Why+can+I+not+lock+wheel+to+take+off+wheel</link>
<guid isPermaLink="false" >https://tr.ifixit.com/Answers/View/331865</guid>
<pubDate>Sun, 21 Aug 2016 08:51:50 -0700</pubDate>
</item>
<item>
<title><![CDATA[Porter-Cable PC60TAG: Why is my grinding wheel spinning slower than usual?]]></title>
<description><![CDATA[<p>The grinding wheel is not spinning as fast as it used to. It sometimes looks wobbly.</p>]]></description>
<link>https://tr.ifixit.com/Answers/View/308696/Why+is+my+grinding+wheel+spinning+slower+than+usual</link>
<guid isPermaLink="false" >https://tr.ifixit.com/Answers/View/308696</guid>
<pubDate>Sun, 01 May 2016 13:25:11 -0700</pubDate>
</item>
</channel>
</rss>
