<?xml version="1.0" encoding="utf-8"?>
<rss version="2.0"
           xmlns:content="http://purl.org/rss/1.0/modules/content/"
           xmlns:wfw="http://wellformedweb.org/CommentAPI/"
<channel>
<title><![CDATA[iFixit - Answers With Device &quot;Razer Blade Stealth&quot;]]></title>
<link>https://tr.ifixit.com/Answers/Device/Razer_Blade_Stealth?rss=yes</link>
<description><![CDATA[Top Questions according to your query. Only showing &quot;Razer Blade Stealth&quot; questions.]]></description>
<language>en-US</language>
<pubDate>Mon, 06 Jul 2026 23:50:50 -0700</pubDate>
<item>
<title><![CDATA[Razer blade stealth: My lcd is broken for rare blade stealth.]]></title>
<description><![CDATA[<p>My lcd is broken for rare blade stealth. Where do I get a new lcd replacement for the 12.5 inch UHD  screen</p>
<p>⟐ Commented Şubat 18, 2021 at 7:57 GMT-7</p>]]></description>
<link>https://tr.ifixit.com/Answers/View/304111/My+lcd+is+broken+for+rare+blade+stealth.</link>
<guid isPermaLink="false" >https://tr.ifixit.com/Answers/View/304111</guid>
<pubDate>Thu, 18 Feb 2021 07:57:24 -0700</pubDate>
</item>
<item>
<title><![CDATA[Razer Blade Stealth: My battery stopped working?]]></title>
<description><![CDATA[<p>for a long time now my battery life persentage in windows has been going between working and not randomly but starting four days ago my laptop wouldn't start when nott in charger and when i finally checked the battery pannel in  the task bar it said that there was &quot;No Battery Present&quot;</p>
<p>so my question is: How do I fix this? Do I have to open it up and reinstall the battery? or do i have to send it back to Razer?</p>
<p>⟐ Answered Haziran 14, 2021 at 9:03 GMT-7</p>]]></description>
<link>https://tr.ifixit.com/Answers/View/397960/My+battery+stopped+working</link>
<guid isPermaLink="false" >https://tr.ifixit.com/Answers/View/397960</guid>
<pubDate>Mon, 14 Jun 2021 09:03:08 -0700</pubDate>
</item>
<item>
<title><![CDATA[Razer Blade Stealth: Why does my screen flicker every couple of seconds?]]></title>
<description><![CDATA[<p>I have a Razer Blade Stealth late 2016 12.5” 4k i7 7500u. It flickers off and on, on the display every so often. I contacted Razer support and they said it was some graphic drivers that I was missing. I installed all the Intel 620 graphic drivers and it still keeps flickering. I isolated the issue by plugging in an external display and everything seemed fine. No flicker, everything was running flawless.  My warranty already expired so I am trying to find solutions on how to fix this.</p>
<p>⟐ Commented Kasım 28, 2022 at 13:28 GMT-7</p>]]></description>
<link>https://tr.ifixit.com/Answers/View/544825/Why+does+my+screen+flicker+every+couple+of+seconds</link>
<guid isPermaLink="false" >https://tr.ifixit.com/Answers/View/544825</guid>
<pubDate>Mon, 28 Nov 2022 13:28:31 -0700</pubDate>
</item>
<item>
<title><![CDATA[Razer Blade Stealth: Touchpad not Working at all! Please help!]]></title>
<description><![CDATA[<p>My Razer blade's touchpad one day decided to stop working and it has not been working for few months. I have updated all the drivers I could update, but it still is not even working. In the devices tab on windows it says it is working but the touch pad does not do anything (Even when the pointer is visible). Could it be mechanial or technical faluire? and if so please explain how to fix. Thanks :)</p>
<p>⟐ Answer edited Ekim 12, 2019 at 15:38 GMT-7</p>]]></description>
<link>https://tr.ifixit.com/Answers/View/457139/Touchpad+not+Working+at+all!+Please+help!</link>
<guid isPermaLink="false" >https://tr.ifixit.com/Answers/View/457139</guid>
<pubDate>Sat, 12 Oct 2019 15:38:04 -0700</pubDate>
</item>
<item>
<title><![CDATA[Razer Blade Stealth: Replacement batteries keep dying.]]></title>
<description><![CDATA[<p>I bought a replacement battery for my Razer Blade Stealth 13.3” (2017). After installing the battery, it worked fine for a while. Then I left it to charge fully and kept it plugged in while the laptop was powered off. When I came back, the battery wasn’t working at all. I also bought a second replacement battery and installed it and the same thing happened; it worked fine, sustained charge and was charging normally. I left it plugged in and then when I tried powering the laptop on it wouldnt do anything. I used a multimeter to check and saw 0V across the terminals of both batteries. With the dead battery connected and the laptop being plugged in for power, the battery icon on the taskbar shows the battery as normal and plugged in and says “(96% available, plugged in)”, but as soon as you remove the charger the laptop switches off and doesnt power on again (on battery). I’m not sure why this happened since laptops have protection from overcharging. The original battery that came with my laptop works fine, no problems with charging (so it’s not a fault in the charger), the reason I wanted to replace it was because its capacity had decreased and wouldnt power the laptop for longer than 20 mins.</p>
<p>I apologize for the long description.</p>
<p>Any information on why this might have happened would be highly appreciated.</p>
<p>⟐ Commented Aralık 18, 2021 at 7:14 GMT-7</p>]]></description>
<link>https://tr.ifixit.com/Answers/View/702348/Replacement+batteries+keep+dying.</link>
<guid isPermaLink="false" >https://tr.ifixit.com/Answers/View/702348</guid>
<pubDate>Sat, 18 Dec 2021 07:14:50 -0700</pubDate>
</item>
<item>
<title><![CDATA[Razer Blade Stealth: The screws at the bottom of my laptop are loose]]></title>
<description><![CDATA[<p>I can not find a small enough screw driver to tighten the bottom of my laptop, I am worryed that it will break along with the whole PC.</p>
<p>⟐ Commented Temmuz 16, 2019 at 23:46 GMT-7</p>]]></description>
<link>https://tr.ifixit.com/Answers/View/403963/The+screws+at+the+bottom+of+my+laptop+are+loose</link>
<guid isPermaLink="false" >https://tr.ifixit.com/Answers/View/403963</guid>
<pubDate>Tue, 16 Jul 2019 23:46:21 -0700</pubDate>
</item>
<item>
<title><![CDATA[Razer Blade Stealth: Blue screen after battery replacement?]]></title>
<description><![CDATA[<p>I replaced the battery in my Razer Blade Stealth 13” (2017). The laptop indicated that the battery was installed and charged to 100%. But the laptop would crash and blue screen after a few minutes of using it, which it does not do with the battery not installed and has never done previously. Is this a hardware malfunction, or a bad installation job?</p>
<p>⟐ Commented Eylül 01, 2021 at 22:38 GMT-7</p>]]></description>
<link>https://tr.ifixit.com/Answers/View/701072/Blue+screen+after+battery+replacement</link>
<guid isPermaLink="false" >https://tr.ifixit.com/Answers/View/701072</guid>
<pubDate>Wed, 01 Sep 2021 22:38:00 -0700</pubDate>
</item>
<item>
<title><![CDATA[Razer Blade Stealth: My razor is not booting up.. I am stuck with a blank black screen.]]></title>
<description><![CDATA[<p>My razor stealth is not booting up.. I am stuck with blank screen... I have tried sending it to Singapore for service but it was returned as it didn't clear customs there... Any help will be appreciated.</p>
<p>⟐ Answered Şubat 25, 2021 at 0:38 GMT-7</p>]]></description>
<link>https://tr.ifixit.com/Answers/View/470882/My+razor+is+not+booting+up..+I+am+stuck+with+a+blank+black+screen.</link>
<guid isPermaLink="false" >https://tr.ifixit.com/Answers/View/470882</guid>
<pubDate>Thu, 25 Feb 2021 00:38:14 -0700</pubDate>
</item>
<item>
<title><![CDATA[Razer Blade Stealth: Where can I find the torx T5 screws for my laptop?]]></title>
<description><![CDATA[<p>I recently put a new m.2 ssd in my notebook and to do so I obviously had to remove the bottom panel but in doing so, 3 of the screws were stripped and I need replacements for them but cant seem to find anything on amazon or ebay.</p>
<p>⟐ Answered Aralık 29, 2022 at 10:36 GMT-7</p>]]></description>
<link>https://tr.ifixit.com/Answers/View/593543/Where+can+I+find+the+torx+T5+screws+for+my+laptop</link>
<guid isPermaLink="false" >https://tr.ifixit.com/Answers/View/593543</guid>
<pubDate>Thu, 29 Dec 2022 10:36:14 -0700</pubDate>
</item>
<item>
<title><![CDATA[Razer Blade Stealth: Razer Blade Stealth Battery Bloating]]></title>
<description><![CDATA[<p>My Razer blade stealth 2017 is bulging because of a bloated battery.  Anyone else have this issue?  My screws started popping out and I don’t know how long it is safe to continue using this laptop</p>
<p>⟐ Commented Şubat 03, 2019 at 8:53 GMT-7</p>]]></description>
<link>https://tr.ifixit.com/Answers/View/546819/Razer+Blade+Stealth+Battery+Bloating</link>
<guid isPermaLink="false" >https://tr.ifixit.com/Answers/View/546819</guid>
<pubDate>Sun, 03 Feb 2019 08:53:25 -0700</pubDate>
</item>
<item>
<title><![CDATA[Razer Blade Stealth: My touch screen is cracked]]></title>
<description><![CDATA[<p>On my razer stealth blade the outer touch screen is cracked. display is stilll functional, touch screen is functioning only to the right of the crack, its annoying in the middle of the display.</p>
<p>i have no warranty. how can I get it fixed?</p>]]></description>
<link>https://tr.ifixit.com/Answers/View/475948/My+touch+screen+is+cracked</link>
<guid isPermaLink="false" >https://tr.ifixit.com/Answers/View/475948</guid>
<pubDate>Wed, 11 Apr 2018 08:16:42 -0700</pubDate>
</item>
<item>
<title><![CDATA[Razer Blade stealth: Built in microphone not working]]></title>
<description><![CDATA[<p>I did a factory reset and it still doesn't work, so it looks like a hardware problem. Windows is detecting it can says it's working fine. But it doesn't pickup any sound.</p>
<p>Please help!?</p>]]></description>
<link>https://tr.ifixit.com/Answers/View/330691/Built+in+microphone+not+working</link>
<guid isPermaLink="false" >https://tr.ifixit.com/Answers/View/330691</guid>
<pubDate>Tue, 16 Aug 2016 02:48:23 -0700</pubDate>
</item>
<item>
<title><![CDATA[Razer Blade Stealth: After water damage, keyboard is not working.]]></title>
<description><![CDATA[<p>Camping in Seattle, my laptop got quite damp in a backpack without my realizing. It was wet for a few days, I noticed and dried it out the best I could, I opened it up and let it air dry for a day. When I booted it up that evening, the keyboard and everything worked fine. The next morning, I went through TSA, the keyboard stopped working when I got home and tried to boot it up again. I tried to continue drying it out, and it somewhat worked again for a small period, but it's stopped working once more.</p>
<p>Also, somewhat related, the CPU fan is locked at 100% all the time. The laptop is still usable with the touch screen and USB ports, but it sorta defeats the purpose if I can't use the keyboard.</p>
<p>I don't know if the keyboard on these can be replaced, but I'd be very interested if they could be.</p>
<p>⟐ Answered Şubat 01, 2021 at 14:46 GMT-7</p>]]></description>
<link>https://tr.ifixit.com/Answers/View/411660/After+water+damage,+keyboard+is+not+working.</link>
<guid isPermaLink="false" >https://tr.ifixit.com/Answers/View/411660</guid>
<pubDate>Mon, 01 Feb 2021 14:46:29 -0700</pubDate>
</item>
<item>
<title><![CDATA[Razer Blade Stealth: Razer blade stealth 13.3 (2017) not turning on]]></title>
<description><![CDATA[<p>Help! My Razer Blade stopped turning on out of nowhere. The light on the power adapter still turns on but non of the lights on the laptop turn on. I have tried the basics such as holding down the power button for a couple of seconds and removing the battery and plugging in the power adapter but nothing has work so far. If its the mother board is there somewhere I can get a replacement? Thanks!</p>
<p>⟐ Answer edited Aralık 05, 2020 at 6:15 GMT-7</p>]]></description>
<link>https://tr.ifixit.com/Answers/View/606999/Razer+blade+stealth+13.3+(2017)+not+turning+on</link>
<guid isPermaLink="false" >https://tr.ifixit.com/Answers/View/606999</guid>
<pubDate>Sat, 05 Dec 2020 06:15:45 -0700</pubDate>
</item>
<item>
<title><![CDATA[Razer Blade Stealth: Motherboard not supplying enough power to display]]></title>
<description><![CDATA[<p>I recently sent out my stealth for a display problem. Every aspect of my blade works with no problem except the display. The screen itself is black. Touch screen works still too! If you were to shine a light on it and view from a angel, you could see the display faintly. Plugged into a monitor with hdmi and it displayed no problem? So i have gotten my razer blade stealth RMAd. Razer got back to me saying that my laptops motherboard isnt supplying enough power to the display!? Is there an alternate fix or is a mobo replacement my only option?</p>
<p>⟐ Answer accepted Nisan 03, 2018 at 17:59 GMT-7</p>]]></description>
<link>https://tr.ifixit.com/Answers/View/462133/Motherboard+not+supplying+enough+power+to+display</link>
<guid isPermaLink="false" >https://tr.ifixit.com/Answers/View/462133</guid>
<pubDate>Tue, 03 Apr 2018 17:59:14 -0700</pubDate>
</item>
<item>
<title><![CDATA[Razer Blade Stealth: Why is my battery not charging past 95%/Not powering the device?]]></title>
<description><![CDATA[<p>My Razer Stealth is the Late 2016 Model. I just got a new battery for my laptop yesterday and followed the instructions for calibration. I checked on it later in the day and saw that the charging was stuck at 95%. Also, when I unplugged the laptop from the charger, it shut down and did not turn back on until I plugged it in again. I checked Razer Support and tried their fix of uninstalling and reinstalling the battery drivers in Device Manager, but that did not work. Any advice would be greatly appreciated!</p>
<p>⟐ Answer accepted Ekim 18, 2022 at 1:18 GMT-7</p>]]></description>
<link>https://tr.ifixit.com/Answers/View/750618/Why+is+my+battery+not+charging+past+95%25-Not+powering+the+device</link>
<guid isPermaLink="false" >https://tr.ifixit.com/Answers/View/750618</guid>
<pubDate>Tue, 18 Oct 2022 01:18:39 -0700</pubDate>
</item>
<item>
<title><![CDATA[Razer Blade Stealth: How do I replace the SSD?]]></title>
<description><![CDATA[<p>I just need a guide on how to replace my SSD in my 2019 Razer Blade stealth i7-8565u. If anybody has any experince i would greatly appreciate it. thank you</p>
<p>⟐ Commented Ekim 16, 2021 at 2:42 GMT-7</p>]]></description>
<link>https://tr.ifixit.com/Answers/View/613009/How+do+I+replace+the+SSD</link>
<guid isPermaLink="false" >https://tr.ifixit.com/Answers/View/613009</guid>
<pubDate>Sat, 16 Oct 2021 02:42:46 -0700</pubDate>
</item>
<item>
<title><![CDATA[Razer Blade Stealth: Screen hinge isn’t closing all the way]]></title>
<description><![CDATA[<p>When I close the laptop, the bottom right side usually tends to stay slightly open. This isn’t a huge deal, but it looks aesthetically awful. I own the 13 inch gunmetal model just in case anyone was curious.</p>
<p>⟐ Commented Haziran 20, 2021 at 19:07 GMT-7</p>]]></description>
<link>https://tr.ifixit.com/Answers/View/432607/Screen+hinge+isn%E2%80%99t+closing+all+the+way</link>
<guid isPermaLink="false" >https://tr.ifixit.com/Answers/View/432607</guid>
<pubDate>Sun, 20 Jun 2021 19:07:43 -0700</pubDate>
</item>
<item>
<title><![CDATA[Razer Blade Stealth: Laptop screen wont turn on but keyboard and razor logo will light up]]></title>
<description><![CDATA[<p>Is there a way that I can get my laptop screen to work again? The keyboard back lights work and the razor logo on the back of the display works when I turn it on. But I get nothing from the display itself.</p>
<p>⟐ Comment deleted Kasım 24, 2019 at 12:33 GMT-7</p>]]></description>
<link>https://tr.ifixit.com/Answers/View/487305/Laptop+screen+wont+turn+on+but+keyboard+and+razor+logo+will+light+up</link>
<guid isPermaLink="false" >https://tr.ifixit.com/Answers/View/487305</guid>
<pubDate>Sun, 24 Nov 2019 12:33:51 -0700</pubDate>
</item>
<item>
<title><![CDATA[Razer Blade Stealth: Fans are stuttering / turning on then off for a couple of seconds]]></title>
<description><![CDATA[<p>Here’s a video of the problem: <a href="https://www.youtube.com/watch?v=fMcJegoX_us" title="https://www.youtube.com/watch?v=fMcJegoX_us">https://www.youtube.com/watch?v=fMcJegoX...</a></p>
<p>And here’s a video of the problem with full load and high temps on the processor: <a href="https://www.youtube.com/watch?v=6b5Vi-ru6YE" title="https://www.youtube.com/watch?v=6b5Vi-ru6YE">https://www.youtube.com/watch?v=6b5Vi-ru...</a></p>
<p>The fans seem to just not start at all. Is this a fan issue or something bigger?</p>
<p>⟐ Commented Eylül 21, 2019 at 8:10 GMT-7</p>]]></description>
<link>https://tr.ifixit.com/Answers/View/591783/Fans+are+stuttering+-+turning+on+then+off+for+a+couple+of+seconds</link>
<guid isPermaLink="false" >https://tr.ifixit.com/Answers/View/591783</guid>
<pubDate>Sat, 21 Sep 2019 08:10:38 -0700</pubDate>
</item>
</channel>
</rss>
