<?xml version="1.0" encoding="utf-8"?>
<rss version="2.0"
           xmlns:content="http://purl.org/rss/1.0/modules/content/"
           xmlns:wfw="http://wellformedweb.org/CommentAPI/"
<channel>
<title><![CDATA[iFixit - Answers With Device &quot;SteelSeries Arctis Pro Wireless&quot;]]></title>
<link>https://tr.ifixit.com/Answers/Device/SteelSeries_Arctis_Pro_Wireless/All?rss=yes</link>
<description><![CDATA[Top Questions according to your query. Only showing &quot;SteelSeries Arctis Pro Wireless&quot; questions.]]></description>
<language>en-US</language>
<pubDate>Wed, 12 Aug 2026 14:32:02 -0700</pubDate>
<item>
<title><![CDATA[SteelSeries Arctis Pro Wireless: Why does my headset work when plugged in but not power on wirelessly?]]></title>
<description><![CDATA[<p>This is sort of my last resort, as SteelSeries support/the few YouTube videos I have found haven't solved anything. My current Pro Wireless stopped powering via the power button about a few weeks ago very all of a sudden (no lights turn on, no beep to indicate that it is on, and both batteries read on the transmitter as fully charged). It just stopped one day while it was hanging on my monitor (no real damage was ever done on this headset). Here's all the information I have gathered:</p>
<p>1) The only way it functions normally like it did before it stopped powering is when it is plugged directly into my PC via the 8-pin connecter it comes with. It essentially still works, but only when plugged in with the 8-pin connector (excluding usage of the microphone).<em><br />2)</em> When I plug in the charging cable (the micro-USB to USB cable), the light next to the power button doesn't turn on, but it starts breathing (lighting up and then lighting back down on repeat). I have no idea if this does anything. I believe it just means its charging, but it hasn't done me any good so far, as both batteries are recognized by my transmitter as fully charged. My PC also detects the headset under devices with this method, but it is incapable of doing anything with it.<br />3) My updated SteelSeries software recognizes the transmitter, but prompts me to reconnect the headset (which I cannot do because it won't power on wirelessly, and it can't connect to the software through the 8-pin connector).</p>
<p>I have opened up the inside of the headset. Admittedly I'm no expert on this sort of thing, but compared to what I found online it visually looks as if everything is fine/appropriately soldered. Could it still potentially be faulty hardware, even though the headset works like normal when using the 8-pin connector? Perhaps it's a firmware issue that is causing a booting issue, and if so, would there be a way to communicate with the headset and update the firmware using the micro-USB cable? Thank you to anyone willing to look into this problem.</p>
<p>⟐ Commented Haziran 17, 2026 at 14:23 GMT-7</p>]]></description>
<link>https://tr.ifixit.com/Answers/View/738702/Why+does+my+headset+work+when+plugged+in+but+not+power+on+wirelessly</link>
<guid isPermaLink="false" >https://tr.ifixit.com/Answers/View/738702</guid>
<pubDate>Wed, 17 Jun 2026 14:23:04 -0700</pubDate>
</item>
<item>
<title><![CDATA[SteelSeries Arctis Pro Wireless: right speaker is broken should I attempt to repair or switch to wired]]></title>
<description><![CDATA[<p>the point where the right speaker connects to the main headset is broken so no audio comes from it anymore, should I try to replace this headset with a more inexpensive and competent headset (cause cash is tight for me) or should I make an attempt to repair it, like I said only the right speaker is broken and before this happened I would usually play with only the left speaker directly on my ear so it’s mostly a nuisance.</p>
<p>⟐ Commented Mayıs 17, 2026 at 13:01 GMT-7</p>]]></description>
<link>https://tr.ifixit.com/Answers/View/623444/right+speaker+is+broken+should+I+attempt+to+repair+or+switch+to+wired</link>
<guid isPermaLink="false" >https://tr.ifixit.com/Answers/View/623444</guid>
<pubDate>Sun, 17 May 2026 13:01:02 -0700</pubDate>
</item>
<item>
<title><![CDATA[SteelSeries Arctis Pro Wireless: PC not detecting my receiver through the given SteelSeries usb cord.]]></title>
<description><![CDATA[<p>I have been using the headset for a while now and one day it just stopped working. I randomly got an alert that says, “The last USB device you connected to this computer malfunctioned and Windows does not recognize it”.  My headset will connect to the receiver but the receiver wont connect to my PC. I know the issue is not with my PC because I tried connecting through the receiver to my laptop and got the same problem. Any help is much appreciated.</p>
<p>⟐ Commented Nisan 23, 2026 at 10:48 GMT-7</p>]]></description>
<link>https://tr.ifixit.com/Answers/View/705813/PC+not+detecting+my+receiver+through+the+given+SteelSeries+usb+cord.</link>
<guid isPermaLink="false" >https://tr.ifixit.com/Answers/View/705813</guid>
<pubDate>Thu, 23 Apr 2026 10:48:41 -0700</pubDate>
</item>
<item>
<title><![CDATA[SteelSeries Arctis Pro Wireless: Arctis Pro Wireless – Bluetooth LED Flashes 10 Times, Won’t Turn On]]></title>
<description><![CDATA[<p>Hi everyone,</p>
<p>I have an Arctis Pro Wireless (White) headset and the Bluetooth function suddenly stopped working.</p>
<p>Symptoms:</p>
<ul><li>When I hold the Bluetooth button, the blue LED flashes 10 times, then shuts off.</li><li>It never enters pairing mode.</li><li>The headset itself works normally with the base station.</li><li>Firmware is fully updated through SteelSeries GG.</li><li>Factory reset did not help.</li><li>Bluetooth memory clear did not help.</li></ul>
<p>Important note:</p>
<p>The headset fell to the ground right before the issue started.</p>
<p>Volume wheel info:</p>
<p>The volume wheel works up/down normally — and I know it does not click inward (normal for this model).</p>
<p>What I want to know:</p>
<ul><li>Is this symptom caused by a damaged Bluetooth module?</li><li>Could it be a loose connector or antenna cable inside the right earcup after the fall?</li><li>Has anyone fixed this by reseating the BT board or replacing it?</li><li>Is there a known part name/number for the Bluetooth daughterboard?</li></ul>
<p>*</p>
<p>If anyone has experience opening the right earcup or repairing this exact issue, please let me know what to check.</p>
<p>Thanks!</p>]]></description>
<link>https://tr.ifixit.com/Answers/View/926410/Arctis+Pro+Wireless+%E2%80%93+Bluetooth+LED+Flashes+10+Times,+Won%E2%80%99t+Turn+On</link>
<guid isPermaLink="false" >https://tr.ifixit.com/Answers/View/926410</guid>
<pubDate>Sun, 16 Nov 2025 03:10:04 -0700</pubDate>
</item>
<item>
<title><![CDATA[SteelSeries Arctis Pro Wireless: Transmitter base station not working at all]]></title>
<description><![CDATA[<p>I was using my headset like normal, i turned it off put it down and the base station just shut off randomly, when i notice this i checked all the connections to my ps4 i connect the optional DC power aswell nothing turned it back on i also tried connecting it too my laptop. Its like its not receiving power at all because my headset wont connect to the base station so it isnt to do with the display, it just wont work. Im sending it off too steelseries too hopefully get a replacement because the hinge has cracked too. I havent found anyone else with the problem that i had, hopefully somone can explain why this happned and how to fix it.</p>
<p>⟐ Commented Ekim 12, 2025 at 1:19 GMT-7</p>]]></description>
<link>https://tr.ifixit.com/Answers/View/681267/Transmitter+base+station+not+working+at+all</link>
<guid isPermaLink="false" >https://tr.ifixit.com/Answers/View/681267</guid>
<pubDate>Sun, 12 Oct 2025 01:19:43 -0700</pubDate>
</item>
<item>
<title><![CDATA[SteelSeries Arctis Pro Wireless: The Line out on my transmitter has stopped working.]]></title>
<description><![CDATA[<p>I’ve had my speakers connected to the line out of the wireless transmitter since I bought it.  However, there is no longer any signal coming from the line out.  I have tested that the speakers still work and connected another device to the line out but that doesn’t work either, so it has to be an issue with the line out.  I have tried resetting the transmitter in case it is a software issue but still cannot get audio from the line out.   Has anybody had this issue and have a fix?</p>
<p>Many thanks</p>
<p>⟐ Answered Ekim 07, 2025 at 9:41 GMT-7</p>]]></description>
<link>https://tr.ifixit.com/Answers/View/681309/The+Line+out+on+my+transmitter+has+stopped+working.</link>
<guid isPermaLink="false" >https://tr.ifixit.com/Answers/View/681309</guid>
<pubDate>Tue, 07 Oct 2025 09:41:51 -0700</pubDate>
</item>
<item>
<title><![CDATA[SteelSeries Arctis Pro Wireless: Trying to replace power button on PCB]]></title>
<description><![CDATA[<p>The power button attached to the pcb is now working once in a blue moon. Instead of powering it off and charging the battery with the base station, I just charge it with a cable while the headset is still on. If anyone knows which two connections I can short to bypass messing with the power button for an hour or how to replace the power button entirely, I would be very grateful.</p>
<p>At the very least, I know the batteries work. I've tested them with a multimeter and they show proper voltage and last about 15 hours, and work without error when I get the headset to power on. I've also tested the wires that go from the hot-swappable battery pins to the pcb, and they are showing very similar voltage. I've also tried leaving the battery disconnected for about an hour and then plugging it back in and trying the button which worked once, but im not sure if that is a fluke or not. Nothing on the pcb looks broken or damaged either.</p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/egFSaoOOOtHR3YND.standard" width="225" height="225" class="hasMenu hasLarge" alt="Resim" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/egFSaoOOOtHR3YND.huge&quot;, '', 'width=1200,height=1200')" /></div>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/ii1jhcXBBeIprwkT.standard" width="225" height="225" class="hasMenu hasLarge" alt="Resim" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/ii1jhcXBBeIprwkT.huge&quot;, '', 'width=1200,height=1200')" /></div>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/kKTrYbiRVZQaTsuv.standard" width="225" height="225" class="hasMenu hasLarge" alt="Resim" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/kKTrYbiRVZQaTsuv.huge&quot;, '', 'width=1200,height=1200')" /></div>
<p>⟐ Commented Ağustos 21, 2025 at 17:01 GMT-7</p>]]></description>
<link>https://tr.ifixit.com/Answers/View/913116/Trying+to+replace+power+button+on+PCB</link>
<guid isPermaLink="false" >https://tr.ifixit.com/Answers/View/913116</guid>
<pubDate>Thu, 21 Aug 2025 17:01:34 -0700</pubDate>
</item>
<item>
<title><![CDATA[SteelSeries Arctis Pro Wireless: Mic mute button turning off and on (Loose contact?)]]></title>
<description><![CDATA[<p>Hi, does anybody have a guide for opening up the left side of the arctis pro wireless. it feels like the contact for the mute button  is loose, just shaking my head a little mutes or unmutes it.  i sometimes have to press and hold the mute button just so i can speak into the mic.</p>
<p>For the record i have 0  experience in opening opening things up but im willing to learn and have a go at it</p>]]></description>
<link>https://tr.ifixit.com/Answers/View/907308/Mic+mute+button+turning+off+and+on+(Loose+contact)</link>
<guid isPermaLink="false" >https://tr.ifixit.com/Answers/View/907308</guid>
<pubDate>Sun, 13 Jul 2025 22:20:08 -0700</pubDate>
</item>
<item>
<title><![CDATA[SteelSeries Arctis Pro Wireless: Plastic about to break again (second headset) around the ear cup joint]]></title>
<description><![CDATA[<p>How do I prevent my current headset from breaking like the first one and how do I repair the first one?</p>
<p>This is the broken one</p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/qTjPSeh2nZE6PGQo.standard" width="169" height="225" class="hasMenu hasLarge" alt="Resim" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/qTjPSeh2nZE6PGQo.huge&quot;, '', 'width=900,height=1200')" /></div>
<p>This one below is on the verge of breaking the exact same way. There is a crack in the housing coming from the location it attaches and I don’t expect it to last another month. SteelSeries will not fix it, will not sell me parts to fix it and would only sell me a new one. Warranty is not an option</p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/QvHv32VjYduapQda.standard" width="169" height="225" class="hasMenu hasLarge" alt="Resim" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/QvHv32VjYduapQda.huge&quot;, '', 'width=900,height=1200')" /></div>
<p>⟐ Commented Temmuz 05, 2025 at 22:23 GMT-7</p>]]></description>
<link>https://tr.ifixit.com/Answers/View/708697/Plastic+about+to+break+again+(second+headset)+around+the+ear+cup+joint</link>
<guid isPermaLink="false" >https://tr.ifixit.com/Answers/View/708697</guid>
<pubDate>Sat, 05 Jul 2025 22:23:47 -0700</pubDate>
</item>
<item>
<title><![CDATA[SteelSeries Arctis Pro Wireless: Ear cups cracked near the hinge, is it possible to order replacement?]]></title>
<description><![CDATA[<p>After a year of use both earcups cracked on the hinge connector, is it possible to get a hold of those or will I have better luck modelling and printing my own parts?</p>
<p>⟐ Commented Haziran 20, 2025 at 9:59 GMT-7</p>]]></description>
<link>https://tr.ifixit.com/Answers/View/693763/Ear+cups+cracked+near+the+hinge,+is+it+possible+to+order+replacement</link>
<guid isPermaLink="false" >https://tr.ifixit.com/Answers/View/693763</guid>
<pubDate>Fri, 20 Jun 2025 09:59:31 -0700</pubDate>
</item>
<item>
<title><![CDATA[SteelSeries Arctis Pro Wireless: Battery station not charging the battery]]></title>
<description><![CDATA[<p>Whenever the battery is in the battery station it shows that it is fully charged but when I put the battery in the headset it doesn’t turn on as if the battery is empty.</p>
<p>⟐ Commented Mayıs 17, 2025 at 18:32 GMT-7</p>]]></description>
<link>https://tr.ifixit.com/Answers/View/674643/Battery+station+not+charging+the+battery</link>
<guid isPermaLink="false" >https://tr.ifixit.com/Answers/View/674643</guid>
<pubDate>Sat, 17 May 2025 18:32:39 -0700</pubDate>
</item>
<item>
<title><![CDATA[SteelSeries Arctis Pro Wireless: Arctis Pro - The battery is charged but the station doesn't work]]></title>
<description><![CDATA[<p>Hello. For my Steelseries Arctis Pro Wireless, the battery charges as normal and I can connect the headset to the PC through bluetooth. However, the app doesn't recognize that I have the headset so I can't use that functionality. Also, I need to manually connect the headset to the PC each time I turn it on. I can also not see the battery on the docking station, since the display doesn't work. From the outside, it seems that the docking station is completely broken, but it still charges the battery.</p>
<p>It wouldn't be much of a hassle, if it weren't for the fact that the audio is heavily distorted (and is automatically muted) whenever I start a game. So when I play games I have to use another headset, but the Arctis Pro works fine for watching youtube or series.</p>
<p>The problem appeared after a Windows update (might be unrelated I don't know). The docking station has remained safely put on my desk, so no external force. I've tried different cables and ports for the station, no difference.</p>
<p>Any tips? Or do I have to settle for buying a new headset/buying a cable for the headset?</p>
<p>⟐ Commented Mart 16, 2025 at 7:50 GMT-7</p>]]></description>
<link>https://tr.ifixit.com/Answers/View/891578/Arctis+Pro+-+The+battery+is+charged+but+the+station+doesn&#039;t+work</link>
<guid isPermaLink="false" >https://tr.ifixit.com/Answers/View/891578</guid>
<pubDate>Sun, 16 Mar 2025 07:50:02 -0700</pubDate>
</item>
<item>
<title><![CDATA[SteelSeries Arctis Pro Wireless: How can I remove this melted plastic on my headset?]]></title>
<description><![CDATA[<p>Hi, I had my Arctis Pro Wireless for 2-3 years now and the hinges died on me completely at this point. Headset is super loose and I went ahead and bought a replacement part for the casing.</p>
<p>Now I ran into this issue, I don’t know how to remove this “melted plastic” (might be glue i’m not too sure) that they have inside the headset to lock in the outer shell. I have to remove this to be able to transfer the battery port from the old casing to the new one.</p>
<p>Any recommendations would be fantastic.</p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/2CX6sjW4DBqv6V1H.standard" width="282" height="211" class="hasMenu hasLarge" alt="Resim" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/2CX6sjW4DBqv6V1H.full&quot;, '', 'width=1005,height=754')" /></div>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/BWyoDw2WregjO4Zc.standard" width="282" height="211" class="hasMenu hasLarge" alt="Resim" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/BWyoDw2WregjO4Zc.huge&quot;, '', 'width=1600,height=1200')" /></div>
<p>⟐ Answered Şubat 05, 2025 at 16:56 GMT-7</p>]]></description>
<link>https://tr.ifixit.com/Answers/View/886248/How+can+I+remove+this+melted+plastic+on+my+headset</link>
<guid isPermaLink="false" >https://tr.ifixit.com/Answers/View/886248</guid>
<pubDate>Wed, 05 Feb 2025 16:56:44 -0700</pubDate>
</item>
<item>
<title><![CDATA[SteelSeries Arctis Pro Wireless: Teardown required: As I have no audio input from the Mic.]]></title>
<description><![CDATA[<p>Does anyone know of a complete tear-down of this headset.</p>
<p>My son drop his headset when he was younger but since then there is no audio from the mic but the headset does work wireless.  (Just no audio i/p).</p>
<p>Thinking of taking some time out to finally getting around to tear it down to see whats going on, but wanted to see if anyone has done it first so I can follow as a guide.</p>
<p>⟐ Answered Ocak 26, 2025 at 8:32 GMT-7</p>]]></description>
<link>https://tr.ifixit.com/Answers/View/885526/Teardown+required:+As+I+have+no+audio+input+from+the+Mic.</link>
<guid isPermaLink="false" >https://tr.ifixit.com/Answers/View/885526</guid>
<pubDate>Sun, 26 Jan 2025 08:32:05 -0700</pubDate>
</item>
<item>
<title><![CDATA[SteelSeries Arctis Pro Wireless: Left ear speaker very quiet, how to change the speaker]]></title>
<description><![CDATA[<p>how do I change the speaker unit itself from the sealed compartment ? thank you, i would appreciate a step by step help</p>]]></description>
<link>https://tr.ifixit.com/Answers/View/883484/Left+ear+speaker+very+quiet,+how+to+change+the+speaker</link>
<guid isPermaLink="false" >https://tr.ifixit.com/Answers/View/883484</guid>
<pubDate>Sun, 12 Jan 2025 09:44:24 -0700</pubDate>
</item>
<item>
<title><![CDATA[SteelSeries Arctis Pro Wireless: How repairable is the hardware microphone mute button?]]></title>
<description><![CDATA[<p>The mute button for the microphone seems to have a loose connection, as when I turn the mute on or off, it beeps and randomly activates/ deactivates the hardware mute until I tap the left earpiece.  I'd rather avoid replacing the whole headset due to the price.</p>
<p>⟐ Answered Ocak 11, 2025 at 10:14 GMT-7</p>]]></description>
<link>https://tr.ifixit.com/Answers/View/863244/How+repairable+is+the+hardware+microphone+mute+button</link>
<guid isPermaLink="false" >https://tr.ifixit.com/Answers/View/863244</guid>
<pubDate>Sat, 11 Jan 2025 10:14:40 -0700</pubDate>
</item>
<item>
<title><![CDATA[SteelSeries Arctis Pro Wireless: Headset stopped working after firmware update]]></title>
<description><![CDATA[<p>I did a firmware update, waited for it to complete and then swapped the battery as it was low, after that the headset has been completely bricked and not turning on, when plugging it in via usb-c cable, it shows up as a usb drive containing an empty file called START.htm, the headset still functions via aux cable but wireless features are completely gone, including bluetooth</p>]]></description>
<link>https://tr.ifixit.com/Answers/View/880061/Headset+stopped+working+after+firmware+update</link>
<guid isPermaLink="false" >https://tr.ifixit.com/Answers/View/880061</guid>
<pubDate>Tue, 10 Dec 2024 17:24:41 -0700</pubDate>
</item>
<item>
<title><![CDATA[SteelSeries Arctis Pro Wireless: I received a brand new headset but it won't be turned on]]></title>
<description><![CDATA[<p>I purchased a brand new Arctis Pro Wireless directly from Steelseries.com. Opened the box and plugged the transmitter into the PC. The transmitter is working but when I press the power button of the headset, it won't power up. Also, the Bluetooth can not be turned on as well. I checked two batteries with the transmitter and charged them to full but still the same issue.</p>
<p>I also tried to connect the headset directly to the PC with the included USB cable, but the LED of the power will not light and I could hear it keeps connecting and disconnecting (which probably means a bad connection). I do try different USB cables and different PCs but still the same thing.</p>
<p>I submitted a ticket to SS but any comments would be appreciated.</p>
<p>⟐ Answered Nisan 15, 2024 at 22:29 GMT-7</p>]]></description>
<link>https://tr.ifixit.com/Answers/View/827528/I+received+a+brand+new+headset+but+it+won&#039;t+be+turned+on</link>
<guid isPermaLink="false" >https://tr.ifixit.com/Answers/View/827528</guid>
<pubDate>Mon, 15 Apr 2024 22:29:16 -0700</pubDate>
</item>
<item>
<title><![CDATA[SteelSeries Arctis Pro Wireless: The receiver has a burn-in on the display]]></title>
<description><![CDATA[<p>I would like to buy a used headset, but it had a small burn-in on the display witch is in the reciver. Can it be replaiced?</p>
<p>⟐ Answered Aralık 08, 2023 at 5:42 GMT-7</p>]]></description>
<link>https://tr.ifixit.com/Answers/View/677833/The+receiver+has+a+burn-in+on+the+display</link>
<guid isPermaLink="false" >https://tr.ifixit.com/Answers/View/677833</guid>
<pubDate>Fri, 08 Dec 2023 05:42:35 -0700</pubDate>
</item>
<item>
<title><![CDATA[SteelSeries Arctis Pro Wireless: Battery stuck in gamedac]]></title>
<description><![CDATA[<p>Wasn't paying attention and put the spare battery in backwards, don't want to pry at it with tweezers and end up damaging something.</p>]]></description>
<link>https://tr.ifixit.com/Answers/View/826574/Battery+stuck+in+gamedac</link>
<guid isPermaLink="false" >https://tr.ifixit.com/Answers/View/826574</guid>
<pubDate>Fri, 01 Dec 2023 21:25:40 -0700</pubDate>
</item>
</channel>
</rss>
