<?xml version="1.0" encoding="utf-8"?>
<rss version="2.0"
           xmlns:content="http://purl.org/rss/1.0/modules/content/"
           xmlns:wfw="http://wellformedweb.org/CommentAPI/"
<channel>
<title><![CDATA[iFixit - Answers With Device &quot;V-Moda Crossfade Wireless Headphones&quot;]]></title>
<link>https://tr.ifixit.com/Answers/Device/V-Moda_Crossfade_Wireless_Headphones?rss=yes</link>
<description><![CDATA[Top Questions according to your query. Only showing &quot;V-Moda Crossfade Wireless Headphones&quot; questions.]]></description>
<language>en-US</language>
<pubDate>Fri, 14 Aug 2026 20:37:52 -0700</pubDate>
<item>
<title><![CDATA[V-Moda Crossfade Wireless Headphones: No sound from left ear.]]></title>
<description><![CDATA[<p>The left wire on my headphones may have gotten pulled a bit as I am no longer able to get sound from the left side. Is this something that is repairable or worth opening them up and taking a look? These are out of the manufacturers warranty.</p>
<p>⟐ Answer edited Temmuz 18, 2023 at 7:17 GMT-7</p>]]></description>
<link>https://tr.ifixit.com/Answers/View/612017/No+sound+from+left+ear.</link>
<guid isPermaLink="false" >https://tr.ifixit.com/Answers/View/612017</guid>
<pubDate>Tue, 18 Jul 2023 07:17:57 -0700</pubDate>
</item>
<item>
<title><![CDATA[V-Moda Crossfade Wireless Headphones: Intermittent signal to battery side V-Moda Wireless]]></title>
<description><![CDATA[<p>Dear Fellows of the Fixit Community</p>
<p>So I’ve just recently had this issue, more than likely due to having dropped these by mistake.</p>
<p>When playing music via wireless eventually the signal to the headphone with the battery inside would cut out but the other would still continue to play.</p>
<p>I had tested them with a wire to the computer however there was no problem full range of sound for a long time.</p>
<p>Opening this I had thought there would be an issue with the connection of the cables, that may be one of them disconnected from the board.</p>
<p>Put it back together no problem then again the same problem.</p>
<p>Then I had noticed this break in the cable.</p>
<p>In your wise experience should i just pull the cable back inside a bit, soulder the spot in question, then after cold apply some plastic glue with the hot glue gun?.</p>
<p>Kind Regards</p>
<p>AP</p>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/IGVEMGuOnBTPNvjZ.standard" width="169" height="225" class="hasMenu hasLarge" alt="Resim" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/IGVEMGuOnBTPNvjZ.huge&quot;, '', 'width=901,height=1200')" /></div>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/ia2oTsohvgMiny2D.standard" width="169" height="225" class="hasMenu hasLarge" alt="Resim" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/ia2oTsohvgMiny2D.huge&quot;, '', 'width=900,height=1200')" /></div>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/lwo22xYhBIXkVUTE.standard" width="282" height="211" class="hasMenu hasLarge" alt="Resim" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/lwo22xYhBIXkVUTE.huge&quot;, '', 'width=1600,height=1200')" /></div>
<div class="imageBox imageBox_left"><img src="https://guide-images.cdn.ifixit.com/igi/QGpWZJgmnBW3VIGg.standard" width="169" height="225" class="hasMenu hasLarge" alt="Resim" onclick="window.open(&quot;https:\/\/guide-images.cdn.ifixit.com\/igi\/QGpWZJgmnBW3VIGg.huge&quot;, '', 'width=901,height=1200')" /></div>
<p>⟐ Commented Ekim 21, 2020 at 4:41 GMT-7</p>]]></description>
<link>https://tr.ifixit.com/Answers/View/647511/Intermittent+signal+to+battery+side+V-Moda+Wireless</link>
<guid isPermaLink="false" >https://tr.ifixit.com/Answers/View/647511</guid>
<pubDate>Wed, 21 Oct 2020 04:41:41 -0700</pubDate>
</item>
<item>
<title><![CDATA[V-Moda Crossfade Wireless Headphones: Broken internal cable from speaker to headband.]]></title>
<description><![CDATA[<p>I have a pair of M-100 headphones with the a broken internal cable (cut in the external portion from the speaker to headband) Can you help me find a replacement and show how to replace it? thanks a lot!</p>
<p>⟐ Answer deleted Aralık 15, 2019 at 11:03 GMT-7</p>]]></description>
<link>https://tr.ifixit.com/Answers/View/584154/Broken+internal+cable+from+speaker+to+headband.</link>
<guid isPermaLink="false" >https://tr.ifixit.com/Answers/View/584154</guid>
<pubDate>Sun, 15 Dec 2019 11:03:41 -0700</pubDate>
</item>
<item>
<title><![CDATA[V-Moda Crossfade Wireless Headphones: Broken headphone slider/adjuster]]></title>
<description><![CDATA[<p>The slider on one side of the headphones is loose and doesn't lock. Upon further inspection, it appears a small bent brass component is out of place. Is there any way to fix this?</p>
<p>⟐ Answered Ekim 22, 2023 at 18:43 GMT-7</p>]]></description>
<link>https://tr.ifixit.com/Answers/View/820492/Broken+headphone+slider-adjuster</link>
<guid isPermaLink="false" >https://tr.ifixit.com/Answers/View/820492</guid>
<pubDate>Sun, 22 Oct 2023 18:43:59 -0700</pubDate>
</item>
<item>
<title><![CDATA[V-Moda Crossfade Wireless Headphones: Makes noise when turned off]]></title>
<description><![CDATA[<p>Not sure when this started, but when I turn off my headphones while they have any amount of charge left in them, the right-side speaker plays a static sound until the battery dies. My guess is that some wire got crossed and the battery gets a direct link to the speaker when the switch is in the off position, does anyone have a fix?</p>
<p>⟐ Answered Temmuz 05, 2022 at 3:26 GMT-7</p>]]></description>
<link>https://tr.ifixit.com/Answers/View/739010/Makes+noise+when+turned+off</link>
<guid isPermaLink="false" >https://tr.ifixit.com/Answers/View/739010</guid>
<pubDate>Tue, 05 Jul 2022 03:26:08 -0700</pubDate>
</item>
<item>
<title><![CDATA[V-Moda Crossfade Wireless Headphones: short circuit from water damage; does not charge]]></title>
<description><![CDATA[<p>Got caught in heavy rain with my headphones on and didn’t think much of it bc i’m an idiot. They continued to function without issue for a few days (no problems with playback or bluetooth pairing they honestly seemed fine, they also still work when using the cable for a wired connection) but once the battery started to get low i discovered that they would not charge at all. additionally the wires connecting the earcups to the headband quickly became very hot whenever i attempted to charge the battery, still without success. regular phone repair stores have refused to touch them and i really don’t wanna buy new ones, all advice is appreciated!</p>
<p>⟐ Answered Ekim 25, 2020 at 20:02 GMT-7</p>]]></description>
<link>https://tr.ifixit.com/Answers/View/662959/short+circuit+from+water+damage;+does+not+charge</link>
<guid isPermaLink="false" >https://tr.ifixit.com/Answers/View/662959</guid>
<pubDate>Sun, 25 Oct 2020 20:02:51 -0700</pubDate>
</item>
<item>
<title><![CDATA[V-Moda Crossfade Wireless Headphones: Bluetooth function doesn't work]]></title>
<description><![CDATA[<p>The Bluetooth function isn't working on my headphones. It won't connect to anything at all and won't show up on searching devices. Is there any way to fix that?</p>
<p>⟐ Answered Haziran 24, 2020 at 11:19 GMT-7</p>]]></description>
<link>https://tr.ifixit.com/Answers/View/636042/Bluetooth+function+doesn&#039;t+work</link>
<guid isPermaLink="false" >https://tr.ifixit.com/Answers/View/636042</guid>
<pubDate>Wed, 24 Jun 2020 11:19:29 -0700</pubDate>
</item>
<item>
<title><![CDATA[V-Moda Crossfade Wireless Headphones: The screws are missing]]></title>
<description><![CDATA[<p>The screws on one hearphones are missing and cannot find replacement from normal repair store</p>
<p>⟐ Commented Ocak 31, 2025 at 4:34 GMT-7</p>]]></description>
<link>https://tr.ifixit.com/Answers/View/812831/The+screws+are+missing</link>
<guid isPermaLink="false" >https://tr.ifixit.com/Answers/View/812831</guid>
<pubDate>Fri, 31 Jan 2025 04:34:44 -0700</pubDate>
</item>
<item>
<title><![CDATA[V-Moda Crossfade Wireless Headphones: Crossfade Power Switch and Buttons Not Working]]></title>
<description><![CDATA[<p>I have been having what seems like a mechanical problem with the power switch on Crossfade 2 headphones — has anyone explored a fix for it before I attempt?</p>]]></description>
<link>https://tr.ifixit.com/Answers/View/707212/Crossfade+Power+Switch+and+Buttons+Not+Working</link>
<guid isPermaLink="false" >https://tr.ifixit.com/Answers/View/707212</guid>
<pubDate>Wed, 29 Sep 2021 05:45:33 -0700</pubDate>
</item>
<item>
<title><![CDATA[V-Moda Crossfade Wireless Headphones: The right-ear emits loud robotic static [m100]]]></title>
<description><![CDATA[<p>The right ear piece emits a disrupting robotic static whenever the headphones are in wireless mode connected to bluetooth.</p>]]></description>
<link>https://tr.ifixit.com/Answers/View/643499/The+right-ear+emits+loud+robotic+static+%5Bm100%5D</link>
<guid isPermaLink="false" >https://tr.ifixit.com/Answers/View/643499</guid>
<pubDate>Mon, 29 Jun 2020 07:06:33 -0700</pubDate>
</item>
</channel>
</rss>
