Ana içeriğe geç
ATV2 thinks it's on ethernet even when ethernet cable is unplugged
ATV2 keeps saying that "to switch to wifi, remove the ethernet cable". The ethernet cable is NOT plugged in yet ATV2 thinks its is.
Even when I plug an ethernet cable and sometimes configure the connection manually, it does not connect at all.
So with the ethernet cable plugged it does not work, and when unplugged, the ATV2 things it is plugged, hence no wifi! :-(
Any help please? Thanks guys
Bu iyi bir soru mu?
Puan -1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
You have a damaged ethernet port. Probably will have to replace the logic board. AS A WORK AROUND go to System Preferences:Network and remove (delete) the Ethernet Service. This may allow you to use only wireless or a USB Ethernet dongle.
If this answer was helpful please remember to return and mark it Accepted.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
Ibrahim Lahoud sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 2,535
