Batteries not charging, Everything else works
Good Evening,
I have a 17" PowerBook G4 1.67 GHz machine. I have two batteries for it, one NewerTech that I purchased new about a year ago (and haven't used much), the other is the original Apple battery that only gives about an hour of life.
My problem, in a nutshell, is that neither battery charges.
When I plug in the power adapter, I get the green ring for a few seconds, then it turns amber to indicate that it's charging. But the percentage of charge shown in the menu bar doesn't go up. Neither do the indicator lights on the battery. The computer turns on and runs fine when plugged into the power adapter.
I've tried resetting the PMU, with no change in results.
This computer did charge when I got it, but somewhere along the line that stopped working. I suspect a hardware problem.
Any suggestions? If it's hardware, what part do I need to be looking at?
Thanks.
Bu iyi bir soru mu?
