Ana içeriğe geç
Mid 2006 / Model Number: A1181 / black or white case / 1.83 or 2.0 GHz Intel Core Duo processor
418 Soru Tümünü görüntüle
When screw sizes are stated in guides' does the mm(length) include top
When screw sizes are stated in the guides, does the mm(length) include screw-top cap depth? Are shank widths?
Example: LCD REPLACE:
Step 5 — Upper Case ¶
Remove the following 3 screws:
o
One 11 mm Phillips #00 in the middle of the case.
o
Two 14.5 mm Phillips #00.
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Crocdog, that is a question, which only the person who wrote the guide, can answer. Habitually, when measuring any kind of bolt, only the length of the thread part is measured, not the bolt head. Hope this helps, good luck.
Bu yanıt yardımcı oldu mu?
Puan 1
3 Yorum:
Bolts? I thought they were screws.
tarafından
Hioldturkey, I got two answers. You say top IS included. machead3 says otherwise. Threads only. Thanx for your response. it helps.
I can't figure out how to 'accept & return' on this page. crocdog
tarafından
Crocdog, what I said is, that only the person who wrote the guide, can answer it for sure. We do not know how the person measured it. It is not common to measure the bolt head in the length of the screw.
tarafından
Yorum Ekle
En Yararlı Yanıt
Yes - see: fastener measuring the # is the driver size. That number, such as "Phillips #00" or "Torx T5" are not characterized by a linear dimension, but are for the most part arbitrary designations in the same sense as a "Size 8" shoe or dress.
If this answer was helpful please remember to return and mark it Accepted.
Puan 1
1 Yorum:
Hi Machead, I got two answers. You say top IS included.
Oldturkey03 says otherwise. Threads only.
crocdog
tarafından
Yorum Ekle
Yanıtını ekle
Crocdog sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 4
Her zaman: 3,441
