Ana içeriğe geç
Model A1001 or A1025 / 667, 800, 867, or 1.0 GHz G4 processor
Can I use a 800 mhz DVI logic board
I have a PowerBook G4 667 mhz DVI 15 inch with a bad logic board. Can I replace it with a 800 mhz DVI 15 inch logic board? are they interchangeable? Also, what about switching display assemblies from one to the other?
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Yes, you can put a 800 MHz DVI board in a 667 MHz machine, but it is recommended to also install a secondary fan as well (the 667 MHz machines do not have the secondary fan). As for the displays, DVI displays are also interchangeable. You cannot, however use earlier Titanium model displays (Mercury or Onyx machines).
Good luck!
Bu yanıt yardımcı oldu mu?
Puan 1
3 Yorum:
I knew you would know. Can he also go to the 1000 MHz board? +vote
tarafından
yes! but he would need a different secondary fan.
tarafından
Where does a Powerbook G4 Titanium DVI 867 secondary fan plug in?
Please reply to RHBernard@gmail.com of 203-984-2070
tarafından
Yorum Ekle
You may be in luck. There are four logic boards listed for the G4 Titanium. A 667, 800, 867 and a 1000. Ben Eiseman is the parts man around here. He should be able to tell you in the morning which ones will work. Here's the boards: http://www.ifixit.com/Mac-Parts/PowerBoo...
Puan 0
Yorum Ekle
Yanıtını ekle
robert owen sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 9
Her zaman: 965
