5th generation of Toyota's modern full-size sedan.
80 Soru Tümünü görüntüle
How do I change the front parking light bulbs?
Both front parking lights are blown. I can't change them without removing the parking light assemblies. Under the hood there is a white tab on each one with a small phillips screw. I removed those but the assemblies still won't come out. What are my next steps ?
Yanıtlandı! View the answer Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
Pro Tech Toolkit içeren veya $100,00tüm siparişlerde ücretsiz kargo!
Mağazamıza Göz Atın
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Mark, follow this:"
1 Open the hood on your Toyota Camry and locate the parking lights. They are on the outside of the headlights toward the front fender.
2 Remove the clip, if your year Camry has one, that protects the bulb ballast. Pull up on the clip to remove it.
3 Remove the electrical plug running to the bulb ballast. Squeeze the release tab on the electrical connector and pull the plug off.
4 Turn the bulb counterclockwise to unlock it and pull it out of the housing.
5 Install a new bulb. Installation is the reverse of removal." from here. There are more directions on here as well. Hope this helps, good luck.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
Mark sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 Gün: 1
Son 30 Gün: 4
Her zaman: 1,245
