Ana içeriğe geç
Suzuki FA50 Moped için onarım ve sorun giderme bilgileri.
Why won't it start?
My fa50 won't start. It gets good spark,gas,air,and air compression. Why won't it start?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 2
4 Yorum
What have you tried so far? Tried to squirt a bit of gas into the spark plug hole and try to start it, just to make sure it does get fuel?
tarafından Paylaş
yes but dies once gas burnt
tarafından Paylaş
jwhiteboy68, is this the same moped? Are you rodneylambert45? Just making sure we are dealing with the same issue here.
tarafından Paylaş
Here to, won't start normal ,does wel with startpilot at airfilter. When warm motor ,starts fine with kick only.
tarafından Paylaş
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
the main jet needs to be cleaned in the carb .. take off the carb and clean it out
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
Sounds as if you are not getting fuel from the carburator into the cylinder correctly, if it were me, I would remove and then clean that carburator by use of some instructions from a repair manual.
Puan 1
Yorum Ekle
Yanıtını ekle
rodneylambert45 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 36
Her zaman: 3,338
