Ana içeriğe geç
The Kenmore Elite HE3 is a washing machine by Kenmore.
668 Soru Tümünü görüntüle
Soru Kapandı
it wont turn on and none of the lights come on either
kenmore HE3 washer i had been using it went to start a load and nothing no lights would come on and it wouldnt start.
Bu iyi bir soru mu?
Puan 0
1 Yorum
and yes i checked to breaker box and unplug it for 30 min then re-plug it in still nothing.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Caroline Moorhead, make sure that you have proper voltage at the plug. Use a voltmeter to make sure that it has power. Otherwise, here is what the manual suggest:
1. Check the line voltage and for blown fuses.
2. Check for voltage going to Central Control Unit (CCU) by listening for a click in the CCU when unit is plugged in. If no click replace CCU.
3. Unplug the unit before continuing.
4. Check continuity of line cord and line filter.
5. Check harness connections to CCU.
6. Check touch-pad/LED assembly.
You can try and download the manual from here for more info. Hope this helps, good luck.
Bu yanıt yardımcı oldu mu?
Puan 1
2 Yorum:
Thank you so much oldturkey i have a manual but it dosent say anything on how to check the (CCU) but my model # is 42922 kenmore elite HE3t so where can i find the correct manual. Thanks Very Much Caroline
tarafından
Caroline Moorhead, is it the same manual that I linked to?
tarafından
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 964
