CDMA version of the fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. 16 or 32 GB / Model A1349 / CDMA compatibility.
422 Soru Tümünü görüntüle
iPhone screen is black but phone is working
My iphone 4 screen has gone black, but the phone is still working. I had the screen replaced last spring and it's been working fine since then. Today it goes black but is still working. I have not dropped it or anything, I just can't see anything. Does anyone have any ideas what has happened and what can I do to fix it? Thanks.
Yanıtlandı! View the answer Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 2
Yorumlar:
tarafından
Yorum Ekle
Pro Tech Toolkit içeren veya $100,00tüm siparişlerde ücretsiz kargo!
Mağazamıza Göz Atın
Ever fixed something? That’s Genius.
Share your repair story with #ImAGenius
We Are All Geniuses
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Melissa, before trying to purchase a new LCD, try to reset your phone. Hold the sleep/wake button at the top right and the home button at the same time. Keep holding until the screen go black. Sometime you have to keep holding even after the red power off slider appears. If it does, just keep holding it. Once the Apple logo appears let go of the buttons, your phone should now reboot. Always make sure that you back up your phone promptly so as to minimize any loss of important data. After you back it up you could also try a restore. If that does not accomplish anything, it may be time to disassemble your phone, check all the connectors, and then consider a new LCD.Hope this helps, good luck.
Bu yanıt yardımcı oldu mu?
Puan 2
Yorumlar:
it just worked for me woooohoooo
tarafından
Thank you it just worked for me too after me googling this for the same problem!!
tarafından
Yorum Ekle
Yanıtını ekle
Melissa sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 Gün: 5
Son 30 Gün: 21
Her zaman: 7,378
