Excessive noise coming from rear drum; shaft area.
Why is the excessive (grinding) noise only happening in curtain cycles...would this still be a bearing issue as I'm not hearing the noise in "HIGH" spin cycle...If the problem is the inner and outer bearings, can they be replaced without replacing the entire rear drum?
Bu iyi bir soru mu?
