Replaced home button now grey vertical line and distorted screen
Hello all you finest folks out there.
My home button was acting up almost since new and I was putting up the replacement untill just recently it virtually stopped working. So I ordered a home button from online store somewhere in china and after studying breaking down (no pun intended) procedure I ..well...broke it down. I took it all apart and replaced a home button then carefully put it back together in reversal. I didn't forget anything because I double checked and made sure that ribbon cables aren't pinched or kinked in any way. I firmly seated all connectors and put it all together. Turned the phone on and to my huge disappointment I found a half-inch wide grey vertical line across the screen and everything is distorted. When I boot the phone I can see some shades of green (where the battery symbol should be while on charge) and when I slide finger on the home screen the phone unlocks. One can see the blurry colors - a distant reminder of icons but it feels that the image was just smashed together in to the half inch thick line. Please not that everything worked before taking it apart . Ironically the home button works as it should...and is unusually easy to push :->
Anyways now to my main question...does it sounds like a screen issue or as a logic board ? Because I wouldn't mind shelling out 50-80 for a new screen but I definitely not going to pay 200+ to replace the board.
Any suggestions?
Thank you for your time
Bu iyi bir soru mu?
