Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Parçalar ve Aletler
iPhone'un 5. jenerasyonu. Cihazın onarımı basittir; tornavidalar, kanırtma aletleri ve sabır gerektirir. GSM/CDMA / 16, 32 ya da 64 GB / Siyah ya da Beyaz.
3022 Soru Tümünü görüntüle
Soru Kapandı
iPhone 4S won't turn on after Battery removal and reinstallation
Hello,
My power and volume buttons were getting loose so I had to open my phone up and tighten those screws, I had to remove the battery and the shield to get access to it. After putting it back together it wont turn on! I did double check every flex cable/connector, and checked if the battery was properly fitted so I know that isn't the problem.
However the screw holder that would screw in to the top part of the plate that covers the battery & antenna shield has fallen out, and I am wondering if that could be the possible cause of my phone not booting. If not, what could be?
Bu soruyu yanıtlayın Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
salam...
maybe you broke the battery connector in the process which is difficult to fix. but before jumping to conclusions hard reset the iphone which happens by holding and keeping on pressing both the sleep button and the home button at once until the apple logo shows up.
Malik.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorumlar:
I've already attempted the hard reset
tarafından
Yorum Ekle
Try taking out the battery and plugging it into the wall via USB. Don't use a computer, plug it into a wall outlet.
Puan 0
Yorumlar:
Won't turn on, so could this be an issue with the logic board then?
tarafından
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 3,884
