Ana içeriğe geç
Model A1225 / Early 2009 / 2.66, 2.93, or 3.06 GHz Core 2 Duo processor
163 Soru Tümünü görüntüle
How to configure ssd as a first drive
Hi, I´m going to install a SSD in my Imac 24 inch 9,1 ( early 2009 ) replacing optical unit and use the HDD as a second unit.
How I Should format SSD to install mountain lion for use it as a system unit?? Should I put TRIM enabled??
Will lost speed if I will install SSD replacing Opitcal unit? or Its better to install SSD in HDD place and keep optical unit?
Thanks in advance and sorry for my bad english.
Bu iyi bir soru mu?
Puan -1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hi, Here is a link to a previous answer to your question that may help you. Good luck.
SSD in Optical Drive Bay
Bu yanıt yardımcı oldu mu?
Puan 1
2 Yorum:
Thanks, and what about configuration to use SSD as a system unit??
tarafından
Once you have the SSD installed and install a working OS on it, all you need to do is go into the startup pref settings and select it as the boot volume (system), and restart.
tarafından
Yorum Ekle
Yanıtını ekle
Pedro sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 3,198
