Ana içeriğe geç
Released in October 2003, the iBook G4 replaced the iBook G3 as Apple's portable consumer computer. The iBook G4 was sold in 12" and 14" models and updated for the last time in 2005.
530 Soru Tümünü görüntüle
Soru Kapandı
How do I replace the connector where the AC adaptor plugs in?
My ibook G4 works perfectly, but something is loose inside the receptacle where the power adapter plugs in and it will not charge. I have another G4 with a crashed hard drive but a working connection (I've been using it to charge the battery) that I can pull the part out of, but I need directions on how to remove and replace it.
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
mdaly513, looks like the connector is soldered onto the DC-in board. for the 2004 it's part number 922-6461 and it is available right here. Of course you can also take it out of your other computer:-). Here is what the manual says about the 2004 model:" Preliminary Steps
Before you begin, remove the following:
• Battery
• Bottom case
• Bottom shield
Procedure
1. With the computer on a soft cloth, disconnect the DC-in cable from the underside of
the logic board.
2. Remove any tape that holds the cable to the frame or logic board.
3. Route the cable from the guides in the chassis.
4. Remove the two identical screws from the DC-in board.
5. Tilt up the DC-in board, and pivot it out of the frame.
6. Remove the DC-in board from the computer assembly.
7. Install the replacement DC-in board, and reassemble and test the computer.
Or you could just check on here for your model and pick the proper guide...:-)
Hope this helps, good luck.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 468
