The screen did not display
dell laptop core 2. the screen did not display sometime they will be different color stroll down the screen, how can i fix that someone told me that the screen as damage.
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Its a bad screen. This series have a couple screens that were duds. its present in a clients E6400.
Bu yanıt yardımcı oldu mu?
First try using it with an external monitor by connecting via VGA cable, if it works fine in such way then the problem is surely with your LCD connecting cable. However you can first try to locate if there is any lose contact of on board connectors which shall might help.
Otherwise you can order new screen online and replace it by following some online tutorials.
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 297
3 Yorum
It is possible that your LCD is failing i.e. bad TAB etc. Try an external monitor and see if it displays without difficulty.
oldturkey03 tarafından
I can see it, but it is very dark. Is it repairable?
Cindy tarafından
That means that your backlight is not working. It is possible that it is a failed CCFL. It might help if you tell us which laptop you have.
