Ana içeriğe geç
Released on October 23, 2012. Core i5 or Core i7 Processor. Apple Fusion Drive.
208 Soru Tümünü görüntüle
Soru Kapandı
Installed a second hard drive, why can't the computer detect it?
I recently purchased the late 2012 Mac Mini with the intention of adding a second hard drive to it. I took an old OWC Extreme 6G 120gb SSD from my tower and was able to install it into the Mac mini (following the iFixit guide and purchasing the data doubler) relatively without incident. Computer booted back up, but the drive is not being recognized anywhere. It doesn't show up in Disk Utility or anything. The SSD is recognized fine by my tower when I put it back in to test, however.
Any thoughts? Thanks for your help.
Bu iyi bir soru mu?
Puan 0
4 Yorum
What kind of tower do you mean here, Windows or Mac? Do you have an external Firewire or USB case/cable that can house your SSD to test it out?
tarafından
Hello Dan, my tower is a Mac Pro 2010. It had 2 SSDs running so I took one for the Mac Mini. It seems to work fine when I put it back into the tower. I will try again with a USB hard drive enclosure and report back. Thanks for your help.
tarafından
Let us know what you discover.
tarafından
Alright, I placed the SSD into an enclosure and hooked it up via USB, and it worked! So, I guess it's not a problem with the drive. Could it possibly be the SATA cable that is messed up? It was a brand new one that came with the data doubler kit from OWC.
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
The only logical answer here is the cable is bad.
Bu yanıt yardımcı oldu mu?
Puan 3
1 Yorum:
Yep I broke down and had a technician look at it, and that seems to be the case! Luckily OWC is being pretty cool about it and will send me a replacement at no cost. Thanks for your help.
tarafından
Yorum Ekle
I have am older macbook pro 5,1 that had similar problems, the drive I put in the optical bay would sometimes be recognized, and sometimes not. Other times it would read in very strange ways. The original optical drive had stopped working, and I noticed the cable was not mating with the receptacle properly. I ordered a cheap replacement cable from gainsaver and voila,everything worked.
If you had problems with your drive before replacing it, try replacing the cable if the new drive is not mounting
Puan 1
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 3,135
