Ana içeriğe geç
Google-branded tablet with a 7" screen. The device needs only prying tools and screwdrivers to fix. Model number: ME370T.
150 Soru Tümünü görüntüle
Soru Kapandı
USB OTG adapter cable doesn't work as promised
Device: ASUS Google Nexus 7 16GB.
OS: Got it with Android 4.1.1 that immediately updated to 4.1.2. Now Google sent an update to 4.2.
Problem: To get an USB stick running at the device as a "drive" (shown as folder for opening it).
References:
Vendor at AMAZON.
Video at YouTube.
The adapter doesn't work as suggested. Even a direct connection of a stick (several typed tested!) doesn't work... - with or without "StickMount".
However 1: All WLAN drives from several PCs are shown (that's normal).
However 2: I get a keyboard and a mouse running properly.
But I need/want my sticks shown by the NEXUS.
However 3: Sure, I can connect the Nexus to one of my PCs where also Sticks are plugged and exchange any datas in any way.
Thanks in advance for any good advice.
Bu iyi bir soru mu?
Puan 0
1 Yorum
@ Seamus,
at first: THANKS.
ROOT? - I'm s simple user. I purchased the adapter, detected the StickMount software and did install it by the offered procedure. - That's all I was able to do.
Is there a special way to install StickMount? (At present I'm using the update version Android 4.2.)
BTW: When I use the WLAN for seeing the other PCs and connect a stick to my notebook and release the stick in the notebook explorer I can see and open the notebook and the connected/plugged stick using the APP "ES Datei Explorer". Then I can access the stick in a "normal" way.
Also: I can connect the N7 to the notebook and "open" the N7 as "drive".
But: "Did you root your device?" - No idea.
Best regards, Manfred
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Did you root your device? Without root stickmount does not work.
Update
use nexus media importer it works without read but the nexus can only read media and not write (btw the nexus media importer is not free you have to buy it if you want to look at pictures etc.. from the sticks etc.. sorry.)
Update
oh and just search the internet for android root but you lose waranty if you root :/
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 7,674
