CPU Temp spike after SSD install
I put a Samsung SSD into my MBP yesterday. After doing so, my CPU temp spikes dramatically, hitting about 240F before shutting down. I thought it may have had to do with indexing the new drive, so I installed SMC to run the fans at full blast, then put it outside to see if it would get over the hump after indexing, but no dice.
I tried booting from the original hard drive via USB to see if that would help, but got the same result.
What should I be looking for, if anything, when I reopen the machine?
Thanks, and Happy Thanksgiving!
Yanıtlandı! View the answer Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorumlar:
What happens when you take it out and if needed put you old HD back?
tarafından
Yorum Ekle
Pro Tech Toolkit içeren veya $100,00tüm siparişlerde ücretsiz kargo!
Mağazamıza Göz Atın
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
In general you CPU temp shouldn't change unless a process is running. You could look at Activity Monitor to see what process is using up the CPU cycles.
It's possible you have a bad SSD or cable as well here.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorumlar:
i'll fire it back and try to look at activity monitor before it shuts down. i haven't dropped the old HD back in yet to see if that stops the madness. thanks for the tips. i'll let you know if there's a resolution!
tarafından
good call on the activity monitor. MDS and MDSWORKER were running at 100%+. i disabled indexing and we're back to reasonable numbers. thanks!!!
tarafından
Happy you isolated down the cause. If your all set here can you score & mark the question as answered - Thanks!
tarafından
Yorum Ekle
Yanıtını ekle
Christopher Padgett sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 2
Son 30 Gün: 18
Her zaman: 1,716
