Ana içeriğe geç
iPhone'un 5. jenerasyonu. Cihazın onarımı basittir; tornavidalar, kanırtma aletleri ve sabır gerektirir. GSM/CDMA / 16, 32 ya da 64 GB / Siyah ya da Beyaz.
2192 Soru Tümünü görüntüle
How to fix iPhone 4s No Service / Searching Problem?
How do you fix the iPhone 4s No Service/Searching problem? What causes the problem? Please help. Thanks.
Bu iyi bir soru mu?
Puan 173
33 Yorum
Hello i have a problem with my iphone 4S.. it show me network searching.... i try all solutions such as remove sim card, go to settings cellular etc.. nothing is go. Anyone can help me ..
tarafından
Below solution worked for me
A solution is to set the date and time manually. If you take out the battery on the iPhone (iOS 6.xx) the date will be 1970.. :p
When you have set the date and time, remove the sim card and put it back in.. This should work :)
tarafından
tarafından
Try switching your sim card to other phone to see if it work. And other sim card on your phone. I did just that when no other trick works only to find out that my sim card is faulty.. Hope this help.
tarafından
Hello. my home used iphone 4s shows "no service" any time i insert SIM. What could be the problem. can anyone help me?
tarafından
28 tane daha yorum göster
Yorum Ekle
12 Cevap
Filtre ölçütü:
Seçilen Çözüm
I fixed one with this issue today. It was caused by the blue inductor coil. I replaced it, and all is well.
Bu yanıt yardımcı oldu mu?
Puan 65
17 Yorum:
Thanks from me too. I think this is iPhone 4s !@#$ week for everyone.
tarafından
tarafından
Hello i got a problem my iphone 4 s is disabled and it has no service how can i get it to stop being disabled without going to the company to go fix it
tarafından
Hi I got the problem in my I phone 4s it shows me network searching I try all solution remove sim card ,airplane mode etc but my sim is working with other phone just 5 months before I bought .how can I fix it any one can help me
tarafından
I insert sim but it show no Service how to fix it
tarafından
12 tane daha yorum göster
Yorum Ekle
(you kan also connect the phone to the WiFi to automatically set date and time. Do the same with the sim card, when the time is right :) )
Puan 27
12 Yorum:
Hi, I had the same issue after changing the power button. I had tried all options given on the net and I can confirm that the answer that alex gives worked for me.
Many Thanks
tarafından
I think this is more of a comment - or affirmation of solution-' than a non-answer and I'm voting it as such.
tarafından
that worked for me perfectly, I just didn't get why apple haven't fixed it yet with new IOS, I have 8.1.2 on my iphone 4s and after battery dies you will have to play with date/time everytime
tarafından
i did set the time and date manually to the present day. Then i remove and reinserted the sim. Nothing happened. Still the same. Please help me :(
tarafından
tarafından
7 tane daha yorum göster
Yorum Ekle
You could also try to put in a sim card without a pin code, and then go to Settings -> General -> Cellular -> "enable 3G" or for iPhone 5 "enable LTE", if 3G/LTE don't show up, go back to General -> Cellular. And then se if it shows, enable and disable fast a couple of times and 3G should appear in the status bar. When it shows, wait for a couple seconds with "enable 3G" on, 2-3 seconds later disable it and enable it again. There you go, you should now be able to get a service, on operator locked iPhones, you will have to activate the phone, but then you could use your original sim card on the phone to activate it. You may have to activate through signing in with Apple ID.
Any questions just comment
Puan 10
1 Yorum:
tarafından
Yorum Ekle
There tons of possible reasons. I found this scheme which includes all Fixes links and short guides
by LetsUnlockiPhone you can click on any issue to get detailed fix
Puan 5
1 Yorum:
tarafından
Yorum Ekle
Manually set the time and date.
that will fix 'searching issue.'
Puan 3
1 Yorum:
Anwar Areekkal's solution worked!
"A solution is to set the date and time manually. ...
When you have set the date and time, remove the sim card and put it back in.. "
02/23/2015 by Anwar Areekkal
Resetting Network Settings did not help.
Note: Prior to changing Date & Time to manual (it's located under General settings), I looked for the Cellular setting. It did NOT exist.
After I did the manual change of time and date (simply turned off automatic) and removed and put the SIM card back in, that Cellular setting showed up!
However, it was OFF, so at first it looked as if this tip did not work. However, go into that setting, turn on cellular AND turn on 3G and everything was fine!
Mine was an iPhone 4. Back in business. Thank you, Mr. Areekkal!
tarafından
Yorum Ekle
data and time set must c...........
Puan 2
Yorum Ekle
i took out sim turned off phone turned on and inserted sim the service was found (three) 2 bars then it went off searching again after resetting settings and repeating my first actions still the same held down the round button untill voice dial screen appeared then cancelled voice dial then my phone found network 3g and wifi and now works ok hope this helps somebody else thank you to previous writers for their guidence
Puan 1
Yorum Ekle
I haven't gotten my answer yet!
Puan 1
1 Yorum:
How can I factory set my iPhone 4s
tarafından
Yorum Ekle
My 4s Apple iPhone went into a searching and no service mode today. I contact my carrier att diagnostics were ran nothing happened. I was advised to go to an att retail store and have them insert a new sim, I did that. No service and searching continued. The att rep advised me to take to an Apple Store. I did not instead I went home. I telephoned Apple Store and was told I needed an appointment or either com in early close to when the store opens and I may get lucky to be on a waiting list. Oh I forgot to mention there weren't any available appointments until Tuesday January 9, 2017. Hm this happened on Monday January 2, 2017. In the meantime as I spoke to the gentlemen at te Apple Store he ran diagnostics and wasn't able to detect the issue. Later that night I decieded to reset the phone to the original settings. Later that night while had just fallen asleep I began to receive text Mssgs. I reached for the phone sure enough it was up and running, I noticed in the upper left hand corner on the screen it said 3G. Well anyway it's working again and no one helped me but me. Just sayin!!! Therefore if you ever run into the issue of your phone searching/no service do not hesitate to reset back to factory setting that may very well correct the issue and save yourself some time. Good Night!!!
Puan 0
Yorum Ekle
The defect in the absence of service is by placing the phone on the flight mode and monitoring the signal if it takes a relatively long time. The fault is in the Ic besnamtT responsible for the network frequencies. If the time for the signal to appear, the files and the rest of the circuit related to the service
Puan 0
2 Yorum:
@bashar22 what is that you are exactly saying? Some of this seems to get lost in translation.
tarafından
The problem ic besbant
tarafından
Yorum Ekle
Please I need a help,I don’t have a network service on my iPhone 4s, please what is the solution, please help
Puan 0
Yorum Ekle
You have to wrong your time on your PC / computer and open your iTunes on your computer and connect your iPhone 4sto the computer and try to correct your time both on your iPhone 4s and the same time with your computer please try this out it
Puan 0
Yorum Ekle
Yanıtını ekle
Allan sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 11
Son 30 gün: 22
Her zaman: 391,163
