Model No. A1367 / 8, 16, 32, or 64 GB capacity
1296 Soru Tümünü görüntüle
My I pod wont charge
hi guys my iPod wont charge it is out of battery and i plugged the USB into my computer and it comes up with the apple sign and then turns itself back off again how can i fix it?
Yanıtlandı! View the answer Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
Pro Tech Toolkit içeren veya $100,00tüm siparişlerde ücretsiz kargo!
Mağazamıza Göz Atın
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
lallana fan, try to charger it on an AC charger and see if that makes a difference. the Ac charger will supply a higher amperage and it is possible that the battery has discharged below its threshold. If that does not help, start by cleaning the dock connector. Use some isopropyl alcohol and a few puffs of compressed air. Check for broken, bend or corroded pins. also, try a different cable. If none of that works, replace the battery. Use this guide to get it done. If nothing else it will give you a known good starting point, should further troubleshooting become necessary. Hope this helps good luck
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
lallana fan sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 0
Son 30 Gün: 0
Her zaman: 478
