How do I get a damaged screw out?
Hello. Some repair dude damaged the screw that hold the battery connecter. How do i get that screw out? I cant use a screwdriver..
Bu iyi bir soru mu?
Bu iyi bir soru mu?
I use the Precision Screw Extractor Set. Here's where to get a set: Precision Screw Extractor Set
Bu yanıt yardımcı oldu mu?
I tried Screw Extractor Set for stripped screws on the back of a 2014 Macbook Pro and found them useless. Also, no instructions included. Do not recommend.
I'm referring to iFixit's 4PC Screw Extractor Reversible Set which did not get the job done. Maybe something from a different source would be more effective?
Haven't tried it myself, but maybe filling the damaged screw head with instant glue before using a driver or extractor would help. Careful not to get the glue beyond the edge of the screw head, between screw head & case!
what worked for me on the back of a mac portable was to put a thin drill bit in and use some pressure and run the drill in reverse (unscrew). The drill bit actually broke so it had a flat end with the thread. Luckily, the flattened drill bit worked quite well for 2 stripped screws and didn't damage the threads in which the damaged screws sat. I suppose a screw extractor in place of the drill bit would work with the electric drill too??
There is so many different procedures....
Take a look at these links :
The 12 best ways to remove stripped screws
If this answer was helpful please remember to mark it accepted.
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 807
