The Sony Ericsson W810i is a Walkman mobile phone with a camera and music playing capabilities.
8 Soru Tümünü görüntüle
Only turns on when plugged into charger just flashes sony screen
My w810 won't turn on I think it is because for one it won't charge and second when I plug it in to charge it only gets to the sony ericsson screen then resets doing it over and over I have tried to connect to the pc to reflash but it won't recognize it poped up once could not recognize but never again I think it's because it had just a thread of charge left in the battery I think it's a hardware issue i'm wondering if there is something I can do any help would be much appreciated thanks.
Yanıtlandı! View the answer Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
Pro Tech Toolkit içeren veya $100,00tüm siparişlerde ücretsiz kargo!
Mağazamıza Göz Atın
Ever fixed something? That’s Genius.
Share your repair story with #ImAGenius
We Are All Geniuses
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
crayzze, the reason for not charging could be a bad battery. Start by replacing that one, follow this guide. Make sure that you charge port is in good working condition, and that no debris or corrosion is present. Try a different cable as well. With a new battery, at least you will have a known good starting point should further troubleshooting be necessary.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
crayzze sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 0
Son 30 Gün: 6
Her zaman: 1,255
