Changing Rear Left Side Tail Lamp
How do I change the Rear Left side Tail lamp?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Pop out two plugs inside the tailgate opening and remove the two screws under them, this will allow you to "pop" the taillight assembly loose from the vehicle. Once that is done, you can disconnect the electrical plug to remove it from the vehicle. If you are just replacing the bulbs, you don't have to do that, but it makes it easier. Twist the bulbs you need to replace counter-clockwise to remove them, or move all of the bulbs to the new part if you are replacing the entire assembly.
Installation is the reverse of removal, the link below has a video that shows the process in good detail.
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 4,492
