blank screen 27 inch thunderbolt
my display has a blank screen.It powers up
what could i do????
Bu iyi bir soru mu?
what could i do????
Bu iyi bir soru mu?
Try it with another Mac with a Thunderbolt port first. That failing, call AppleCare.
Bu yanıt yardımcı oldu mu?
I have the exact same problem. When connected to my laptop, the laptop shows that the display is plugged in and working but there is no display, no back-light, nothing.
I am solving it by replacing the video controller main board inside the display itself. I know my particular problem is due to a bad ribbon cable connector on the main board. This particular ribbon cable carries all the video data to the LCD display.
If a replacment board isn’t available here:
[bağlı ürün eksik veya kapalı: IF359-000]
A replacement (re-manufactured) board can usually be found on eBay for between $50 to $200 depending on seller and location.
This guide goes over how to remove the main board. It’s actually a guide to replace the Mini Display Port/Magsafe Cable, but doing that requires removal of the main board so the guide still works.
Apple Thunderbolt Display Thunderbolt & MagSafe Cable Replacement
I wish to note that I just conducted the repair exactly as I noted above and my display is back to perfect working condition!
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 1,982
