Ana içeriğe geç
The Atari 2600 or Atari Video Computer System (VCS) is a video game console released in September 1977. The 2600 runs a MOS Technology 6507 CPU and uses ROM cartridges for storing games.
32 Soru Tümünü görüntüle
does not come on
my old atari does not coime on whern conected to tv . is there a fuse or something is there a wireing guide, if i take i t apart what elect checks can I do. It set in the garage for several years, I thought it would be fun to plsy with my great grand son .I have power to the unit from the power supply unit ,the tv works fine. connections seem tight are there any units still for sale ? it was a lot of fun to play it years ago . I tryed several different games none of them worked, so I assume its the controller.
Bu iyi bir soru mu?
Puan -1
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
donald smith, I just checked the diagram and I can not seem to find a fuse per se. I would disassemble the console and take a look at the capacitors as well as all traces. There is always a possibility of dried out and broken components as well as bug (the entomology kind) damage. I attached an image which does have the values attached to it, this may help you to check components with a multimeter. Hope this helps, good luck
2600 Motherboard silk screen
2600 Chanel 3 Switchboard Schematic
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Several possibilities exist for this. The first is that the power supply itself is bad. These have a high failure rate now because of the age. The other possibility is that the power jack or power switch is loose, and needs the solder reflowed. The solder on these boards is weak from age, most units I work on all need reflow. There are also a few capacitors on these that need replaced. This usually won't cause it to completely be dead though, most likely you would see partial static, blank screen, or color bars. Make sure the cartridge slot and cartridges are clean. Nothing more than rubbing alcohol is needed to clean them.
Puan 0
Yorum Ekle
Yanıtını ekle
donald smith sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 1,528
