Ana içeriğe geç
Model A1224 / Mid 2007 and Early 2008 / 2, 2.4, or 2.66 GHz Core 2 Duo processor
605 Soru Tümünü görüntüle
replace ssd on this iMac 20"
I want to replace my old hard drive with a new ssd.
I can remove the old and insert the new inserting it with this adapter or not?
http://www.amazon.it/OCZ-SSD-3-5-Adaptor...
thank you all!
Yanıtlandı! View the answer Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
Dizüstü Bilgisayar Bataryaları
An easy fix for a big power boost.
Hemen Alışveriş Yapın
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
looks like it should be low profile enough to fit in the same space as the regular HDD
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
I have replaced my 320HHD in my 2210 Imac with a 240GB SSD using the mounting plate that came with the SSD. There is plenty of room in the drive bay to instal the SSD. Mount the SSD in the mounting plate, hook it up and using double sided tape I mounted the plate vertically in the drive bay. Closed up the Imac and it has worked fine ever since.
Puan 0
Yorum Ekle
Yanıtını ekle
Elvio sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 0
Son 30 Gün: 0
Her zaman: 1,107
