The Kenmore Elite HE3 is 7.2 cu. ft. capacity electric dryer by Kenmore.
242 Soru Tümünü görüntüle
The control display does not work.
"I have a Kenmore Elite HE3 dryer. The control panel does not work. when i open the door the inside light is on. When I do the diagnostic test of time up and down, the display lights up with code 88. PLease help. model #1110c82832100"
Yanıtlandı! View the answer Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
Pro Tech Toolkit içeren veya $100,00tüm siparişlerde ücretsiz kargo!
Mağazamıza Göz Atın
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Laurie, try to push the door switch button and see if the light goes off in the dryer. It is possible that this is caused by a bad door switch. You can check it for continuity with an ohm meter to make sure. Also check your thermal fuse which is located right next to the thermistor on the blower wheel housing.You can use an ohm meter to check it for continuity or take the wires off and jump it, use alligator clips or electrical tape to tape them togethe. This is for testing purpose only, DO NOT RUN your dryer that way. If none of this works, it is most likely the control panel user interface or the control board. Download the service manual from here for more information. Hope this helps, good luck.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
Laurie sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 1
Son 30 Gün: 17
Her zaman: 1,803
