Can't remove two bolts from oil pan in my 2000 VW Beetle
I am trying to replace my oil pan (bad drain plug threads) and I can not remove the two bolts closest to the transmission. I went and bought a wably #10 socket and it didn't help either. The socket extensions are blocked by the transmission case. Does anyone have any helpful tips?
Bu iyi bir soru mu?
5 Yorum
I welded a 10mm socket to a 5 mm hex wrench so they both made contact at the same time worked great make sure you line them up using a bolt you removed already
chris harey tarafından
I used Triton # 12714 ( Kragen auto parts) Extra Long Metric Ball End Hex Key Set. Included 5mm. Ball end allows up to 25° angle. Best $7.99 I have spent in a long time!
dalefugate tarafından
The 6mm hex head allen bolts on my timing belt pulley are totally stuck... I don't have access to an impact wrench, but I have tried drills, but will not move the bolts...HELP
MeKisha Lemke tarafından
Finally got a larger star bit hammered into the head of the bolt. No fun at all! Now onto the water pump... thanks for your help!! Going to buy new bolts for sure. I have read that I should replace the motor mount bolts too.. better safe than Stuck.
The next option was a left handed drill bit.
