Why does my wifi card show 'No Hardware Installed'?
I was using my macbook as usual when suddenly it froze. after a force restart it turned back on however the wifi stopped working. when i click on it, it says no hardware found. tried doing a clean install of the os but still no luck, but got worse because there isnt the wifi signal on the status bar.
any help pls ?
Bu iyi bir soru mu?
9 Yorum
Same issue here with my mid 2010 15" MBP. Problem seemed to start shortly after I installed OS X Yosemite. Bluetooth still works (which I strange because they share a card). I also replaced the card, reset SMC and PRAM. Still nothing. Grrrrr. Guess I'll have to take it in.
aplinmercer tarafından
Did you find a solution for the error? I have the same problem and have tested everything. Also got the problem last summer and have been trying to find a solution.
petterwendel tarafından
Same problem MacBook Pro 2011. Even replaced Airport Card but no improvement. New airport card work for about 1 week and now I am back to "no hardware installed". 10.11.4 . Also tested 10.10.5 to ensure it wasn't a software problem.
justanick tarafından
Try replacing the flat airport card cable, it can have issues after some years of use.
Monte Ohrt tarafından
1¢ solution, take a small ammount of low tack tape, and tape the cable down onto the optical drive. This forces the frayed bits of the cable into alignment completing the circuit.
Robert Wiebe tarafından
4 tane daha yorum göster
