Ana içeriğe geç
Model A1046 or A1095 / 1280x854 screen resolution
118 Soru Tümünü görüntüle
Soru Kapandı
Display won't stand at all. Can it be fixed by hinge replacement?
I have a PowerBook G4 who's display will not stand up at all. The screen itself works fine. One of the hinges was broken by something trapped between the screen and the body as it closed. There's a visible dent on the screen's "knuckle" 2-3 inches from the edge.
As I remember, the other hinge worked for a while but couldn't hold the weight and broke after a few months.
Will replacing the hinges be enough to fix display?
Will the dent be a problem?
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
You may need to just tighten the screws on the right and left hinges, here's how to get to9 them: PowerBook G4 Aluminum 15" 1-1.5 GHz Right Clutch Hinge Replacement
PowerBook G4 Aluminum 15" 1-1.5 GHz Left Clutch Hinge Replacement
PowerBook G4 Aluminum 15" 1-1.5 GHz Left Clutch Hinge Görseli
Kılavuz
Zorluk:
Çok zor
PowerBook G4 Aluminum 15" 1-1.5 GHz Right Clutch Hinge Görseli
Kılavuz
Zorluk:
Çok zor
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 2
Her zaman: 151
