DisplayPort cable damaged? Display not being recognized with new one
I think I damaged mine. I opened it to replace the optical drive, and when I was going to close the system. I didn't inserted the ribbon in a parallel way, resulting in a dented ribbon, I just received the DisplayPort ribbon/cable and to my surprise my display is not being recognized. I'm using an external display now.
I did a SMC PRAM reset, I took the RAM away and reinserted again but nothing happens.
is there anyway to replace it by myself? I'm not in the USA.
Thanks Oldturkey03, pollytintop and Dan: The EMC is 2389. The display doesn't work at all, no backlight no picture, it is not even being detected. Right now I'm working with a Plasma TV.
I had the same problem with the original data ribbon which has the SN: 593-1280 REV A and then part I ordered from Macpartsonline is 593 - 1280A ICT 1611 which appears to be the same except for the way how the code is shown. There is no visible damage on the socket itself.
The ribbon plugs in both sides naturally, its a perfect fit, so unless the new ribbon is also damaged I blame the display port socket, since the display was fine before I dented the old ribbon, maybe I stretched the socket or broke some pin.
I checked the diagnose LED's and it just the first three lit.
Bu iyi bir soru mu?
5 Yorum
what is it that you want to replace? the display? if you put the old dented ribbon in, is your display working at all? have you checked that the part you have is correct?
pollytintop tarafından
Also can you give us the last 4 digits of your serial number so we can correctly ID your system here as you have iMac 27" & 21.5" listed.
Dan tarafından
I just added some extra info about the issue.
JIgzat tarafından
Than you very much oldturkey03, I guess I will need a micro soldering expert to do that.
I found the reference in aliexpress.com and alibaba.com I guess is going to be like the lottery to get the part from china sellers.
I'm going to try to find someone who lend me his computer to test the cable and the display just to make sure that the socket is indeed damaged.
Thank you very much again.
JIgzat tarafından
You are welcome. Good idea about making sure that it is the socket :-)As for ordering parts from Alibaba.com I have been doing so for years and have not yet had any trouble.
oldturkey03 tarafından
