The camera doesn't switch on
device: aiptek CUO-DT1
problem: The camera doesn't switch on
description: My old camera doesn't switch on and I don't know why. I only know that the camera requires particular bateries, and I'm using those bateries, I recharged them just yesterday! I add some photos, but I can't do more. I simply don't know what do.
This is the camera:
I take apart the case to show you what there is within:
The black piece was inside the camera, I don't know what it is, it just came off.
Bu iyi bir soru mu?
Giovanni Riva, see if you can get a close up of your logic board. It seems that service manuals for this camera are hard to come by. Make sure that you have power on the leads coming of the battery case, check the switch with a multimeter as well. Did the camera just quit working or did anything happen to it?
oldturkey03 tarafından
Anything happen! tomorrow I'll take apart it and show you the logic board and the other components. I said tomorrow becouse here it's almost midnight!! :) thanks you!!
Giovanni tarafından
anytime is fine:-) no reason to hurry.
I hate this camera!!! it is impossible to take apart! now I'm trying to find new screws to take off, but no one take down the piece that I must remove, or better... only one, but is between the big cylinder and the switch. This by the point of view of the last photo. If you see the camera from above it is under the switch but it is also perpendicular to the switch so I can't remove it!
Giovanni tarafından
Yes, it is embarrassing but... I broke it. Not a big damage, realy! I only destroy the thread!!! but I promise that it was impossible to take off that screw :) I'll ad some photos!
Giovanni tarafından
14 tane daha yorum göster
