Ana içeriğe geç
Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 16 or 32 GB capacity / black or white plastic back.
1961 Soru Tümünü görüntüle
iPhone not working, screen tabs broken and it doesnt come on
I replaced the battery which seemed to work but then the tabs 1 and 2 fell off that were attached to the screen. So we used metal tape and electrical tape to try and put them back because soldering wasn't sticking. now it doesnt turn on and tab number 7 wont stay down! The main machine seems to work tho, it starting making the same sound as when I received emails but the screen doesn't work, Is this junk or can I fix it?
Yanıtlandı! View the answer Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
MacBook Pil Tamir Setleri
Başlangıç $69.99
Buy Now
Başlangıç $69.99
Buy Now
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Meghan Locke, when you say " tabs 1 and 2 fell off" I suppose you mean connector 1 and 2, #1 is for the LCD and #2 is for the touch screen. #7 is for the antenna. Now when you say you tried to solder but it would not stick, I assume you are talking about soldering the connector back to the logic board. Unless you have the right tools and the experience, this is a very difficult task. Sticking it on the board with tape is not going to accomplish this. It will not make any contact with the board. I strongly suggest that you find somebody locally who is equipped to solder those connectors back on the board. Hope this helps, good luck.
Bu yanıt yardımcı oldu mu?
Puan 3
Yorumlar:
Thanks, Its usually very expensive tho so I was trying to figure something out, but I realize now that I need to get it professionally done, thanks for your help
tarafından
Best of luck to you...
tarafından
Yorum Ekle
Yanıtını ekle
Meghan Locke sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 0
Son 30 Gün: 0
Her zaman: 143
