Change rate of turn signal on 2000 Chrysler Town and Country?
The left front turn signal blinks very fast. How can i change the front left turn signal bulb on my 2000 Chrysler town and country?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Rachel San Miguel, the bulb that needs to be changed is not the one that flashes fast :-) The fast blinking is usually an indicator that one of the bulbs is burned out. Check the rear indicator light bulb and cable connector. Make sure the bulb is properly seated. Hope this helps, good luck.
Bu yanıt yardımcı oldu mu?
Improper bulbs for example some led bulbs can cause this as well
This should help you.
https://www.youtube.com/watch?v=w-4M51yp...
If you need help finding the part, here you are:
http://www.autozone.com/autozone/parts/S...
The part isn't guaranteed to be the right one, since I don't know the specific edition of your vehicle, but it should be close enough. Best of luck.
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 1,456
