logic board / display connector L9000 coil charred
The small SMD coil (L9000) under the display connector on the logic board is charred.
The display connector was damaged previously (broken shield) and every time I was transporting the iMac I had to either smack it or open it and wiggle the display cable in order to make it work.
This time it might short-circuited one of those pins to the ground (the twisted wobbly shield) and hopefully only that inductance died.
Here is a picture from the crime scene: http://cl.ly/image/222v2L222z1M
I wonder if there are any options to repair it.
Bu iyi bir soru mu?
5 Yorum
What are the last three digits of your serial number? What numbers are on your motherboard? What processor is it?
oldturkey03 tarafından
Serial: CK0330CRGXU EMC 2390
iMac 27" Intel i7
Where should I find the numbers on the motherboard, I took off the screen but I don't see anything on the PCB that would look like a serial or type, do I have to remove the logic board completely (to see the CPU side)?
Laurian tarafından
that should be enough information to find out what you want to know :-)
Did you get in hold of the right inductor? If so, where did you get it?
Thanks!
ulflundqvist tarafından
Might this work? http://www.digikey.com/product-detail/en...
