Where is the throttle position sensor at in a 2005 kia optima
where is the throttle position sensor at in a 2005 kia optima
Bu iyi bir soru mu?
Bu iyi bir soru mu?
The throttle position sensor is located on the side of the throttle body assembly (the assembly that the air intake hose connects to from the air filter box) There are 2 screws that retain the TPS to the body and 1 wire connector.First remove the wire connector from the sensor,then using a screwdriver remove the 2 screws. Hope this helps good luck.
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 3,535
