Having problems re-installing OS
hello world!
PowerBook + G4 +17 in Albania.
Have one big problem on to operation system,
At first he was in version 10.3 ....
But in many applications, "update your system to install".
(Example - skype, chrome, and other)
---> 1 Step = Download torrent 10.4 .... (CD 4) PowerBook system,
---> 2 Step = Initially I tried to start from (1 USB - but did not give any result in BOOT)
---> 3 Then, Burn 4 CD,
1 (boot-first) + Error or another version should begin.
2 (BOOT not start to enter this CD2)
3 (BOOT not start to enter this CD3)
4 (BOOT not start to enter this CD4)
---> 4 Step = After several days, the 4 CD outlines a DVD.iso
and finally went on smoothly, work from DVD.iso
---> 5 Step = Reboot and press "C" button, select Boot From DVD....
In the above process was to 89% ... loading, but the DVD was not in the paper.
after about an hour of ( Turn off - Power button )
The situation now is that there is no system left
If someone has an idea about this problem, to comment below.
or contact http://www.facebook.com/klodjan.bardhi
Thank You All
Bu iyi bir soru mu?
1 Yorum
Klodjan - You should create your own question instead of placing it here. Don't forget to supply as must information on your system as you can.
Dan tarafından
