rusty water in radiator
bold text just bought car looked in radiator,see rust ?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
jackie, the number one thing that you do want to get done is a good coolant flush. It is possible that somebody just water instead of antifreeze. You also should make sure it is rust and not that your antifreeze has gone bad. You need to flush it out good man. It can make a mess when it gets goopy. Repeat a complete flush in a few month. Hope this helps, good luck.
Bu yanıt yardımcı oldu mu?
I'd take it to an Auto Zone and have them test the coolant. This will tell you if it's just water and rust or the level of antifreeze protection it has. If none, then follow old turkeys advice.
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 188
